Looonie wrote:Why would you care?
Just go to Pick A Part and pay $8 for an OEM oil cooler from a Pajero.
Unless you want shiny bling silver bits? I'd put more faith in the Mitsi OEM part than a $300 china kit.
NOLAW wrote:cheers guys, im looking at a few options at the moment but the setrab option is looking pretty good, it is a bit more on the pricey side but like metric said iv put too much money and effort into my setup so far to go cheap and risking it all as oil is the life line of an engine pretty much.
Im planning on pairing it up with a NZKW relocation kit that i purchased a while back, anyone delt with these kits? and if so any probs with leaks etc?
limbo wrote:One point to look into is not to get too big a cooler as over cooled oil is no ones friend... hence the water vapor out of my catch can.......
limbo wrote:I put on a setrab in my supra, the cooler was the cheap bit, the AN fittings cost about the same again. I run a oil thermostat as well as oil filter relocation so there a few extra fittings.
the danger with cheap ones is they could crack at high pressure and temps, the only way you will know this is when you or the people behind you skid out or you loose oil pressure and kill your engine.
Better off going quality and smaller.
blitza wrote:limbo wrote:One point to look into is not to get too big a cooler as over cooled oil is no ones friend... hence the water vapor out of my catch can.......
ummmmmmmmmmmmm why?
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
