wde_bdy wrote:Mine uses 1500kg springs, gives a bit more leeway on what you can safely load. Often its the hubs and tyres that are the limiting factor on a single axle.
Callum
xsspeed wrote:What would you be towing on a single axle trailer thats much more than 1000kg?
matt dunn wrote:xsspeed wrote:What would you be towing on a single axle trailer thats much more than 1000kg?
I load all my stuff into the car and trailer when we go places,
Car is usually 1000kg, then 100L of fuel, Jack, axels stands, 8 spare wheels on the tyre rack, spare gearbox, toolboxes and heaps of other stuff, the car is usually packed full before it goes on the trailer,
plus the weight of the trailer itself.
Wouldn't surprise me if at times it was close to 2000kg on a single axel trailer.
Emperor wrote:Ill check what our load rating is.. Kea single axle, and it holds my rx7, the stagea, r32s, even a safari lol
~SlideWays~ wrote:matt dunn wrote:xsspeed wrote:What would you be towing on a single axle trailer thats much more than 1000kg?
Does it have suspension? If so, do you know what the rating is?
Lloyd wrote:~SlideWays~ wrote:matt dunn wrote:xsspeed wrote:What would you be towing on a single axle trailer thats much more than 1000kg?
Might wanna check the tyre load ratings also. Even commercial stuff will be pushing the limits
