ch4ng wrote:By those numbers the C56 will be the only one that has a shorter 3rd and 4th ratios gear ratio. However it also has a longer 1st gear as well which will mean a higher top speed in 1st (but it'll take a bit longer to get there)
If you're happy with your current 1st gear would you consider using your current 3.545 1st gear in the C56 box
I had a play with this calculator and have a look at the road speed chart (note the speeds are in Miles per hour)
Enter the details you have including tyre size and you can see the speed difference at any given RPM
eg: using the C50 and C56 details and a 195/60R15 tyre size it showed at 6000rpm
C50: speed in KMH
1st 53.1
2nd 98.2
3rd 143.2
4th 193.1
5th 228.5
C56: speed in KMH
1st 49.9
2nd 82.1
3rd 112.7
4th 151.3
5th 189.9
TRD Man wrote:1st gear is essential in a rally car.
Generally, with the same final drive, the differences in ratios between C52 & C56 aren't enough for you to notice and won't make an ounce of difference to your stage times.
The 4.3 diff ratio is interchangeable between the boxes so I'd suggest you go with the box which is in better condition.
If it's a toss up - C56 is your man.
Make sure that the LSD is in 2 way mode before installing.
TRD Man wrote:The 4.3 diff ratio is interchangeable between the boxes so I'd suggest you go with the box which is in better condition.
TRD Man wrote:I just typed a long answer & it vanished when I went to upload it. God I hate that.
Essentially we had a number of FWD Corolla rally customers who were smashing the shallow ramps on over-run in new diffs. This is not a part you could buy but we were very lucky to get some out of Japan.
They come new in the 1 & 1/2 way position and by changing to the 2 way mode there was no room for the spider to move and the problem went away.
Whether there's a downside at all depends on how you drive. In 2 way it could bite on over-run and induce a bit of understeer. You should have your foot hard into it anyway.
Some nice data there Neil. The AE011 TRD kit actually works very well in the gravel with a 4.733 ratio.
