themaleman wrote:is there a common place people T into to power things such as boost controllers? would the stereo power be ok?
themaleman wrote:is IG2 ment to have power when there is no key in the barrel? because black-red dose. also what fuse would you use? ive found that brown-white only has power when in ON position. so ill use that for boost controller power
themaleman wrote:black-red = has constant 12v power, drops to 7v when cranking
black-yellow = has 12v when switched to ON, and drops to 7v when cranking
brown = has constant 12v power, drops to 7v when cranking
brown-white = has 12v when switched to ON, and drops to 7v when cranking
