BZG|Bling wrote:Flat bar bent / drilled to suit would be a better long term solution.
ee904age wrote:You can get proper two-piece clips that go through the radiator between the fins.
cat007 wrote:BZG|Bling wrote:Flat bar bent / drilled to suit would be a better long term solution.
Can you explain what you mean?
cat007 wrote:Are you not worried that the parts of the shroud where the fan's aren't is effectively blocking the flow through the radiator?
