I horyied up a test light to find the 12v, iginition and earth.
But now i dont know what speaker is what. :S
So does any one know the wiring colours?
Ta, James
Dell'Orto wrote:Purple and white are speaker/tweeter wiring. The wire with the two white wires crimped to it are illuminationPassengers side speaker wire is $&#$% too, some mutant chopped it and wrecked it at some point along the way
XSVWGN wrote:Check which wires are going to the speakers in your door panels. That will tell you which is which and that should be easy given your door cards aren't on.
Process of elimination bro
XSVWGN wrote:FRITTER is the word of the day
gasman wrote:took me about 3 day to install mine because mine had one of those factory amplifiers and some other crap. ended up soldering some RCA plugs to the wires that used to run to the headunit so that i could keep running the factory amp.
Users browsing this forum: No registered users and 39 guests
