E51 LSD gearbox - recommended oil? Redline?
Postby gmacrae » Wed Feb 29, 2012 12:39 pm
Hi guys. Looking to replace the oil in the aw11's gearbox soon - pretty sure it's a E51 - haven't even looked. Supercharged LSD gearbox anyway.
I want to use Redline HD shockproof but not sure if that'll suit the diff (not worried if it shudders a bit, just want to protect it) - any opinions out there? The gearbox will probably be getting some abuse, drag slicks etc.
Gene
gmacrae
Postby Bazda » Wed Feb 29, 2012 1:47 pm
Motul Gear FF LSD 75w90.
Postby gmacrae » Wed Feb 29, 2012 1:49 pm
was hoping i'd hear from you Barry, no-one has put those gearboxes thru their paces like you. That stuff is pretty good eh? You tried the redline stuff?
gmacrae
Postby Santa'sBoostinSleigh » Wed Feb 29, 2012 3:00 pm
moved from for sale to tech q's
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby gmacrae » Wed Feb 29, 2012 3:22 pm
oops sorry Santa... brainfart
gmacrae
Postby gasman » Wed Feb 29, 2012 3:24 pm
i used some redline stuff in my corolla when i had it and it was good at first then got worse.
then switched to some AMTEX TRANS LSD 75W90 and it was much better compared to the redline stuff.
"What can possibly go wrong?"
gasman
Postby Mr Ree » Wed Feb 29, 2012 5:32 pm
gasman wrote:i used some redline stuff in my corolla when i had it and it was good at first then got worse.
Its important to mention exactly what Redline oil you used, just so others know that its not actually the brand thats no good, as the specific type used might have been incorrect for the GB in question.
The shockproof stuff isnt a synchros best friend, as the additives in it ends up varnishing the inside of the synchros and make gear selection difficult over time.
Does your box need a GL4 or GL5?
wak thud gush!
Mr Ree
Postby gasman » Wed Feb 29, 2012 8:54 pm
i used the hd shockproof stuff.
gasman
Postby gmacrae » Wed Feb 29, 2012 9:31 pm
something i just read recommends GL5 for the s/c gearbox... not sure i'd trust the source tho. That motul stuff sounds like the ticket anyway
gmacrae
Postby Bazda » Thu Mar 01, 2012 8:25 am
I used the shock proof redline before as I was giving my boxes a hiding.
But over time the syncro cones end up super shiny meaning the syncro cant grip well enough.
Since changed to Motul Gear FF LSD (designed to be used in FWD boxes with mechanical LSDs) and its perfect!
Quite pricey though:
viewtopic.php?t=84670
Postby CAMB01 » Thu Mar 01, 2012 8:26 am
Mr Ree wrote:The shockproof stuff isnt a synchros best friend, as the additives in it ends up varnishing the inside of the synchros and make gear selection difficult over time.
Yes can confirm this, my evo gearbox is getting harder to get into 1st and 2nd gears and 3rd crunches at high rpm shifts. Going to pull it apart, clean it up replace synchros and use different fluid.
I'm using Redline lightweight shockproof oil.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Mr Ree » Thu Mar 01, 2012 10:21 am
Exactly^
Provided you need a GL4, redline MT90 will be a godsend to your synchros, and transform your shifting.
wak thud gush!
Mr Ree
Postby 4agtepwr » Tue Mar 27, 2012 8:38 pm
The motul gear oil that Baz said is the bizzo! it is pricey but sorted out the aw11's shifting nicely
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby gmacrae » Wed Mar 28, 2012 7:16 am
sweet cheers mate
gmacrae
Users browsing this forum: Google [Bot] and 1 guest
