AE92 DIY exhaust
AE92 DIY exhaust
Postby molex » Wed Feb 29, 2012 8:11 pm
I'm going to build an exhaust for my 20v AE92 Levin, at this stage going to stick with the factory 4/2/1 section so not particularly complex.
Anyone have any recommendations for 2 1/4" vs 2 1/2" on an NA 4a? Not interested in loud, happy to put in muffler/reso and will have the cat intact.
I need some bends, length of straight, a resonator and muffler for less than astronomical amounts of money.
Anybody able to help?
molex
Postby QikStarlie » Wed Feb 29, 2012 8:27 pm
2.5. good reso up front bit after collector -> big chambered muffler at back, inlet/outlet size or 2 bigger than pipe, as very unlikely will flow as much as the pipe -> decent length pipe after muffler, will help quieten it down.
QikStarlie
Postby headshotnz » Wed Feb 29, 2012 9:26 pm
I would go with the 2 1/4 personally, these engines require alot of back pressure. or even step up to 2 1/2 just before the back wheels.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby QikStarlie » Wed Feb 29, 2012 10:47 pm
headshotnz wrote: these engines require alot of back pressure.
QikStarlie
Postby Bling » Wed Feb 29, 2012 10:58 pm
Pretty sure factory is 2 1/4"? That should do the trick.
Postby ch4ng » Wed Feb 29, 2012 11:57 pm
2 1/4" is factory on ae111 blacktops
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Burning Angel » Thu Mar 01, 2012 5:50 am
agreed(with the facepalm)
there's no such thing as an engine needing "back pressure", any thing after the merge into 1 is a restriction an has no beneficial purpose.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby strx7 » Thu Mar 01, 2012 6:31 am
the length of exhaust after the first flow interupter (cat/muffler/resonator) has the biggest factor on how droney it is. think about this when building it.
i'd go with 2 1/4 inch, and 1 x 3 chamber type muffler in the back with NO increase in tip size.
Postby solitaire » Thu Mar 01, 2012 10:42 am
strx7 wrote:the length of exhaust after the first flow interupter (cat/muffler/resonator) has the biggest factor on how droney it is. think about this when building it.
Good tip, so the shorter the less droney? or vice versa?
AE92, KZJ120, KDJ120
solitaire
Postby strx7 » Thu Mar 01, 2012 12:40 pm
yip, if you have a muffler in the middle of the car, it will be droney, for vehicles that have a cat or muffler right up the front, its going to be VERY droney
Postby QikStarlie » Thu Mar 01, 2012 5:18 pm
^ this. after collector inc some pipe length after the actual merge, no exhaust is best. thats not just for peak power either. so dumping into a large diameter pipe after "tuned" length & diameter . then using rest of the system just to quieten it down with zero restriction is the way to go. although will benefit something with aggressive cams alot more than a standard blacktop.
QikStarlie
