Bazda wrote:What is done above is not ideal.
Seen ones like that crack too many times.
Make sure you use flexi joints or slip joints before joining it to the exhaust.
Bazda wrote:Need to be quite small like 40-45mm id. Try trademe first.
cat007 wrote:Bazda wrote:Need to be quite small like 40-45mm id. Try trademe first.
Do you mean put a flexi on both the main exhaust and the wastegate pipe? Or just the main exhaust?
Mr Ree wrote:Yes it does matter what angle you merge the dump tube into the DP at.
You ideally want to have it merging with the least angle possible so there is no abrupt collision of exhuast gasses when the gate is open.
iOnic wrote:Mr Ree wrote:Yes it does matter what angle you merge the dump tube into the DP at.
Is there any actual evidence of this? Just curious because my Evo has the EWG dump tube plumbed at a 90deg angle to the downpipe via a removable adaptor to change it from atmo venting to plumb back. It accelerates much quicker with the pipe in place than venting to atmo.
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
