Soda blaster
Soda blaster
Postby Mr Revhead » Fri Mar 30, 2012 11:32 pm
Has another tried making their own soda blaster?
Really quite like the idea of one for stripping back paint on rusty old cars....
Better than hand sanding anyway :x
Postby Bling » Sat Mar 31, 2012 12:14 am
To blast what? Parts or panels?
Just use paint stripper 8)
Postby Mr Revhead » Sat Mar 31, 2012 8:17 am
Panels/shell. Paint stripper wont remove rust and flakey shit though.
It occurred to me that a sandblaster should work. Just use soda instead of grit
Postby fangsport » Sat Mar 31, 2012 2:37 pm
Mr Revhead wrote:It occurred to me that a sandblaster should work. Just use soda instead of grit
pretty much. just need a finer seive to reuse the blasting medium to keep the rust flakes out.
fangsport
Postby Bling » Sat Mar 31, 2012 3:07 pm
Blasting is sweet, but not ideal for big things (at home). I built a sandblast unit (use garnet though) and the amount of material it spits out is insane. It's all recycled so not a problem. But if you're trying to do big panels / whole shell that's going to be a big mess. Just my opinion though. I think proper rust will survive soda in any case.
Postby Mr Revhead » Sat Mar 31, 2012 6:00 pm
Yes it can make a mess. I plan to use plastic sheets to close off the work area.
Yes major rust will, but it cleans up scale etc with out marking good steel, and also lets you work delicate areas with no damage.
Using grit can warp and damage the surface of panels. Soda blasting can remove paint leaving a good surface underneath. It's sounding a lot more appealing than sanding :lol:
Seeing it appears I can now just use a sand blasting tool, It will be pretty easy to give it a go and see how it works out.
Proper rust will be dealt with grinders and welders :twisted: :lol:
