True-No-Turbo wrote:Yeah,
the ss dog bone joint will give you those symptoms, sounds terrible when they flog out.
sergei wrote:To check them, jack up the car on one wheel (while another is on the ground) and check for "bearing play" on full lock each way.
~SlideWays~ wrote:Manual, must be high spec model because its an LSD box.
Plenty left in the pads on drivers side, haven't looked at passenger side pads. Rotors look fine, not a major lip on the edge or anything.
Checked it tonight by doing a 'wheel bearing check' like sergei suggested and found significant play on the front passenger side (even though I was sure the sound was drivers side). There isn't any wheelbearing noise btw, the play makes the whole strut move, but if I grab the spring I can't make it move.
Is there a way I can tell if its the dog bone/fig8 joint without taking it to bits since its our daily for work? Is it possible its another bush or are these symptoms pointing right at worn dog bone joint?
~SlideWays~ wrote:Is there any special way to remove the joint? Looks like there might not be enough room to simply undo both nuts and slide the bolt out, looks like it'll foul.
