MRP Custom made Performance Coilovers - Exceptional Quality!
Postby Shrike » Mon Nov 28, 2011 10:26 am
Hmmmm ill flick you an email before the deposit date ends im just trying to think if I should get gt4 mounts on all 4 ae111 coilovers as I cant remember if there was any difference on the front ones (I know they bolted up but I cant remember if there was movement) Ive just got to get my hubs back and confirm
will there be any difference in price? and im assuming that your braided brake lines for you brake kits (when I get a set haha) will bolt straight up to these?
What spring rates etc would you recommend car will be mainly track based and driven on the road now and then ie to the track :p I dont mind hard springs and have no problem swapping springs over
On that note what would a set of spare springs cost on top?
also I would be wanting rear camber plates
Shrike
Postby Bazda » Mon Nov 28, 2011 11:06 am
Shrike wrote:Hmmmm ill flick you an email before the deposit date ends im just trying to think if I should get gt4 mounts on all 4 ae111 coilovers as I cant remember if there was any difference on the front ones (I know they bolted up but I cant remember if there was movement) Ive just got to get my hubs back and confirm
Hey
I have drawings for the celica and the front tops are different to the AE111.
Let me know what chassis its bolting up to and what mounts you are running.
You can always buy extra mounts if you wanted as well.
Which ever you choose there will be no difference in price.
Im not 100% on what car this is for, AE111 or Celica....?
For the AE111 I would suggest 8k front and 6K rear setup.
Yes our braided brake lines are to suit all the stock mounting points which these coilovers have as well :)
Postby Shrike » Mon Nov 28, 2011 11:13 am
chassis is ae111 but im running gt4 st185 celica 5 stud 4wd hubs
so the rear coilover mounting points at the bottom of the coilover that bolts onto the hub are different size and spacing between the ae111 and st185 hub if that makes sense
the front hubs are the same but I cant remember if the hole size is slightly lager on the gt4 hubs compared to the ae111 as it bolts up but there may be some movement I can send you pics of what I mean if this sounds weird
Shrike
Postby Bazda » Mon Nov 28, 2011 11:24 am
Shrike wrote:chassis is ae111 but im running gt4 st185 celica 5 stud 4wd hubs
Nope thats easy to understand.
The front bolts should be the same as all the Toyota use M15 front bottom strut bolts. Unless you went and put M14 ones in there.. causing the slop.
M15 meaning you cant buy them off the shelf.
Basically all you need is AE111 coilovers with ST185 rear bottom mounts.
The rears have adjustable camber via a slotted hole on the hub mounting point, the rear top plates are not camber adjustable as you couldn't adjust it without taking the coilover out of the car as the opening hole is way too small through the top. Or you can use camber adjustment bolts.
Postby Shrike » Mon Nov 28, 2011 11:32 am
your onto it so there should be no issue getting something like this? and what spring rate would you reccommend?
Shrike
Postby Bazda » Mon Nov 28, 2011 11:41 am
No issues getting this at all.
8/6 spring setup.
Postby Bazda » Sat Dec 17, 2011 9:09 am
Our numbers are starting to pick up for this 2012 order.
We are also offering a swift spring upgrade for $350
Most likely the best springs in the world, info on them here:
http://www.swiftsprings.net/advantage.html
- Half the weight of a normal spring
- Spring do not need time to settle and they do not sag
I've heard heaps of feedback from guys and they actually improve the ride quality & performance at the same time. Amazing what a spring can do as most would just think its just a rate, all springs are the same.
Postby kim0663 » Sat Dec 24, 2011 5:25 am
wow I've been looking so long on yahoo japan for some coilovers but the price on these seem insane, and fully supported too! lol
What sort of spring rate would you recommend on a stripped out but 99.9% idiotically daily driven sw20? Car has lost about 100kg in body fat, mainly around the cabin/forward area. Not completely sure how much of an effect this would have on choosing spring rates but definitely does not handle the same as other sw20s I have owned/driven.
Running tein springs on yellow bilstiens currently but the ride feels quite 'bouncy'. Not in a bad way but it does give the impression that I might go airborne if driven over a slight bump fast enough. By slight bump, I mean bumps that I'd barely feel on stock setups. I'm hoping to rid this symptom by replacing with coilovers. Shock/spring combos don't seem to work well on mine as front sits much higher than rear. TRD springs, tein springs, same effect. Front sits higher than rears.
I haven't managed to find an account number for deposits etc so if you could pm me details, I may join in on the wagon on this one. Will be looking at the swift upgrade option.
Mr2 GT-S
330ci M
kim0663
Postby Bazda » Sat Dec 24, 2011 9:12 am
kim0663 wrote:wow I've been looking so long on yahoo japan for some coilovers but the price on these seem insane, and fully supported too! lol
Hey, i've sent you a pm.
Most likely your spring rates are not suited to the shock rate, therefore creating a bouncy ride.
Very common when combining diff brand shocks with springs.
Postby Bazda » Fri Apr 20, 2012 4:49 pm
Stock due to be with us Early next week!!
Thanks to all who have put down deposits to hold onto a set.
Wont be long till your riding on MRP custom made coilovers.
We will continue to bring in more and more models as these have been a very popular choice.
Also, if your looking for a level up and have the extra cash to get performance and ride quality like Bilstein/KW/koni etc ($3k+ suspension) check out our Fortune Auto range.
Postby Shrike » Fri Apr 20, 2012 5:32 pm
when I get the coilovers for just track work I will lol but atm I need to get it rolling with an engine first ;)
know anything about running topfeed injectors with the quad throttles?
Shrike
Postby captain crescent » Tue Apr 24, 2012 9:46 pm
Hi Bazda
I have a 2002 Toyota Allex (Runx) ZZE123 . It is a race car it is currently running rally Bilstiens with street springs what do you have to offer on either of your brands / what would you suggest?
Budweiser is a gay beer. if it isn't a gay beer Sam why are you trying to put it up my arse.
captain crescent
Postby Bazda » Tue Apr 24, 2012 10:14 pm
bones on bikes wrote:Hi Bazda
Hey, we can get a custom set made for you with any spring rates and our custom valving.
Will PM you details.
Postby Bazda » Tue Apr 24, 2012 10:47 pm
Teaser of a custom set Inverted Shocks for the real race guys.
Thick shock shafts - Just like Bilsteins :D
Postby Bazda » Thu Apr 26, 2012 10:30 pm
New stock in.
Check out the pics on the first post.
Postby dnalunchie » Fri Apr 27, 2012 1:38 pm
I want some of these for the phat swift!
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Bazda » Fri Apr 27, 2012 3:34 pm
dnalunchie wrote:I want some of these for the phat swift!
If I had a set I could measure off then I could custom make them. As I dont have any drawings for that car.
Postby Leon » Wed May 02, 2012 3:10 pm
What sort of coin would a set of suspension be for an AE92 club car (sedan, 1040kg).
Aim would be: Autocrossing (seal, dirt, gravel), some sprinting (hillclimbs etc) on both seal and gravel, light rally duties. Zero smooth high speed track use.
I'd want to be able to crank it to at least 2 - 3 inches taller than standard height to get me out of the rocks, but not like 10 inches above standard like you'd run at the Safari Rally.
Postby Bazda » Wed May 02, 2012 3:38 pm
Leon wrote:What sort of coin would a set of suspension be for an AE92 club car (sedan, 1040kg).
Roughly be looking around a similar price.
Will send you a PM.
Postby Bazda » Sat Oct 05, 2013 10:04 pm
All Corolla models now in stock!
Return to Toyspeed Sponsors
Users browsing this forum: Google [Bot] and 0 guests
