Shrike wrote:if you use the Mac ae rotors and a set of st185 gt4 celica twinpot calipers its straight bolt up (cant remember about the brake lines tho) plus the gt4 pots are 1-2mm bigger then the s/s ones :p
callum wrote:calipers should nearly bolt straight up. ive done it. you do need to grind a small amout of metal off the bottom of the caliper. doesnt weaken the caliper. the rotors (if using ss rotors) need to be turned down slightly. will do it for a box of beers but im in hamilton.
otherwise I think you just file down part of the s/s caliper so it doesnt catch
magweal wrote:Shrike wrote:if you use the Mac ae rotors and a set of st185 gt4 celica twinpot calipers its straight bolt up (cant remember about the brake lines tho) plus the gt4 pots are 1-2mm bigger then the s/s ones :p
Are the st185 gt4 rotors the same size as the ae101 BZ rotors??
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
sergei wrote:magweal wrote:Are the st185 gt4 rotors the same size as the ae101 BZ rotors??
There are two sizes: 254mmx24mm and 278mmx24mm . The AE101 GT-Apex are 254mmx24mm (I believe).
Grrrrrrr! wrote:sergei wrote:magweal wrote:Are the st185 gt4 rotors the same size as the ae101 BZ rotors??
254 will be non-SS, SS are 275(ish) mm diameter. Possibly same casting as the ST185 rotors but drilled in 4 stud instead of five etc.
xsspeed wrote:Can I get confirmation on the need to grind down the 275mm discs when using a MS AE111 hub with BZR twinpots
Users browsing this forum: No registered users and 32 guests
