Wierd hesitation on Mazda 323 - Sorted, cleaned the AFM
Postby no_8wire » Thu May 03, 2012 11:55 am
My girlfriend has a 2000 Mazda Familia wagon 1.5 ZL that is giving weird issues.
Basically the car was stuttering at low speeds and hesitating then taking off once you reached about 4000rpm.
I replaced the filthy air filter and sparkplugs, which seemed to make a difference to the stutttering.
But the car still feels like it is hesitating struggling to breathe/go under 4000rpm. It has no go or power (even for a 1.5L) but once you reach over the threshold, it picks up and flys in comparison.
Even when the car is stationary and you rev it the car will not freely rev until over 4000rpm. Even with no load it is sluggish and hesitant in how it revs at low rpm.
Any ideas on what I could check?
Its got me stumped at the moment...because it is also somewhat intermittent.
no_8wire
Postby wde_bdy » Thu May 03, 2012 11:59 am
Try cleaning AFM, was a temporary fix on my 1500 Demio. I have two so was able to troubleshoot by swapping parts, had very similar symptoms.
Callum
wde_bdy
Postby no_8wire » Thu May 03, 2012 12:04 pm
The wire with a orange glob on the end on the left of the photo?
I cleaned that softly with carb cleaner and an very small piece of cotton wool.
Do you need to clean up the larger tube as well on the right)?
no_8wire
Postby wde_bdy » Thu May 03, 2012 12:26 pm
Don't think mine looked like that, I just sprayed it full of AFM cleaner from Repco. Was only a temporary fix and I ended up getting a new AFM.
Callum
wde_bdy
Postby sergei » Thu May 03, 2012 2:07 pm
no_8wire wrote:The wire with a orange glob on the end on the left of the photo?
The orange blob is just a thermistor (temp sensor), the real guts are inside of the black tube: you can see it usually covered in crap if you look inside.
Postby no_8wire » Thu May 03, 2012 2:13 pm
Sweet, I will give the insides a good clean and see if that make a difference.
no_8wire
Postby B_giB » Thu May 03, 2012 2:30 pm
The little wire in side is VERY thin, do not touch it with anything, just spray and walk away!
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby no_8wire » Thu May 03, 2012 2:33 pm
Spray from a safe distance, a few short bursts a couple of times rather than a hard long blast... I believe that is the accepted way to do it without damage?
no_8wire
Postby B_giB » Thu May 03, 2012 2:46 pm
Correct!
B_giB
Postby BZG Wagon » Thu May 03, 2012 3:21 pm
There's a thread I have on another forum outlining what happened to my GF's car, plus how I diagnosed it:
http://www.amazd.co.nz/forum/viewtopic.php?f=2&t=19725
Could be of help.
BZG Wagon
Postby no_8wire » Mon May 07, 2012 1:55 pm
Cleaning the afm sorted it... amazing how much difference it makes to driving the car.
Will keep an eye on it to see it if happens again and need to replace the afm, but hopefully it has sorted the issue
no_8wire
