bzrspeed wrote:Put a gze style scoup on your bonnet, then build a rubber sealed box over the trumpets as blacktop is map, suck the nice cold air in and you will get a little power increase.
If you do it right once you dont have to muck around again and again.
Not that hard of job, build a alloy box over the trumpets so it seals tight around the bonnet and then run small filters. Very easy.
BZG|Bling wrote: If you think you'll get worthwhile gains from a stock motor just by changing air intake I really think "you're dreaming".
Users browsing this forum: No registered users and 38 guests
