RomanV wrote:-water wetter stuff? Does this work?
Mr Revhead wrote:Also possibly try a different oil. Some don't transfer heat as well as others. Would depend on how much heat is in the oil. Got temp gauges?
What about switching the fans on earlier?
rollaholic wrote:whats your current radiator? is it a standard one from something? looking at a thicker alternative to the same radiator might help in that case, obviously giving you a bigger coolant volume.
maybe some ducting from the nosecone as well? it looks like at the moment air is prevented from going around the radiator, but its not being specifically directed through it either.
Mr Ree wrote:If you dont want to get an external oil cooler (which would keep your water temps under control)
then making a cheap water sprayer set up would be the next option I would look at, as it will make alot of difference provided you have good atomisation of the water.
That shroud in the pic above wouldnt lend itself to great airflow imo.
Also, I would want to have data on how hot the water is getting, as Im guessing you are currently relying on the factory gauge?
BZG Wagon wrote:Have you got bonnet vents? (might not be the best solution to try first).
RomanV wrote:Fan manually switched on all the time while on track.
Users browsing this forum: Majestic-12 [Bot] and 24 guests
