Link G1 map sensor
Link G1 map sensor
Postby Vertigo » Wed May 16, 2012 3:42 pm
Sup. Looks like Im acquiring a G1 Link for my 4AGTE.
Do I need an external map sensor (guessing they dont come with one built in)? Where can I get these?
Any other sensors that Ill need? Air temp?
The knock sensor and water temp sensor from my current 4AGE should work ok?
Im going to be running 440cc 3SGTE injectors through 4r7 resistors. Anything I should know here?
Ill be wiring it all myself, and hoping it goes ok. Anything else I should consider?
TVIS just kicked in, yo!
Vertigo
Postby d1 mule » Wed May 16, 2012 3:48 pm
my g1 v5 had a built in map sensor. earlier models may not tho
an air inlet temp sensor can be used (is better to have) but is not necessary, the best one to use is a Bosch Porsche turbo temp sensor, about $120 iirc
water temp will be ok, they dont run knock sensors from memory, only the G4s do.
probably be better to run MAP and TPS enrichment too, i didnt have TPS hooked up and tuner said it would be better with it.
d1 mule
Re: Link G1 map sensor
Postby tsoob » Wed May 16, 2012 4:50 pm
Vertigo wrote:Sup. Looks like Im acquiring a G1 Link for my 4AGTE.
consider buying my g4 :P
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby matt dunn » Wed May 16, 2012 8:23 pm
There ard quite a few different trigger combination around for the early G1 links.
I take it that it has a 4AGE sub board in it,
but there is a couple of different ways that the triggers are wired depending on the board.
Postby Vertigo » Wed May 16, 2012 8:32 pm
Well this one was used on a 4AGTE already, tuned for 15psi which is what im aiming for. Im assuming itll be ready to drop in pretty much.
Vertigo
Postby matt dunn » Wed May 16, 2012 8:47 pm
Vertigo wrote:Well this one was used on a 4AGTE already, tuned for 15psi which is what im aiming for. Im assuming itll be ready to drop in pretty much.
Yeah should be,
and all G1's have an inbuilt map sensor too.
Postby matt dunn » Wed May 16, 2012 9:48 pm
What version G1 is it as the V3 and older are not laptop tuneable?
Postby Vertigo » Thu May 17, 2012 9:55 am
Thats a good point. Ive been told it has a computer cable, so probably a later revision G1, Ill confirm. Good info guys, thanks. Keep it coming.
Vertigo
Postby Vertigo » Thu May 17, 2012 9:57 am
tsoob wrote:consider buying my g4 :P
5 hundy? :)
Vertigo
Postby RedMist » Thu May 17, 2012 12:52 pm
matt dunn wrote:What version G1 is it as the V3 and older are not laptop tuneable?
Thought the V3 was laptop viewable, but not changable. Wasn't the V5 the only one laptop tunable? (It's been many years since I've been inflicted by the V1)
I have a hand controller if you so need one.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby loose_unit » Thu May 17, 2012 1:09 pm
V4 is also laptop tuneable, its like the V5's poor cousin, has less stuff and only maps to 8000rpm vs 10000 on the V5.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby matt dunn » Thu May 17, 2012 8:32 pm
No V3 was the last of the hand remote only ECU's,
but a lot of them were upgaded with firmware to V5 specs.
Postby Vertigo » Thu May 17, 2012 9:50 pm
Decided to decline the G1 - too many unknowns.
So.. about that G4, tsoob :)
Vertigo
Users browsing this forum: Google [Bot] and 27 guests
