1I1 wrote:Going off that guide the certifier has to do a road test and provided it meets the standards (comes down braking safely etc) then you can have more than half a degree of camber.
Again thats subjective to tyre width etc isn't it?
Agreed negative camber maximum limits:
The resulting negative camber maximum limit that has been adopted is as follows:
A front or rear suspension system in a low volume vehicle must incorporate no more than half a degree (0 degrees 30mins/0°30’) more negative camber than that specified by the vehicle manufacturer.
In any case where a vehicle’s camber exceeds that recommended by the vehicle’s manufacturer, the LVV Certifier must ensure that the requirements contained in 2.2(2)(a), 2.3(8), and 2.4(1) (referred to earlier in this LVVTA Information Sheet) of the LVVTA suspension standard have been met. The LVV Certifier must also take extra care in ensuring that the vehicle is safe and fit for purpose, based upon the following factors:
tyre width – the effects of added negative camber are more pronounced when wide, low-profile tyres are fitted; and
road and brake performance test results; and
the vehicle manufacturer’s wheel alignment specifications.
strx7 wrote:I pass a S15 on the way to or from work a couple of times a week which i would say is running 10-15 degrees of camber.
tsoob wrote:I will be talking to LVV today re the tyre strech thing and will also talk about this.
will post back
