ae101 rear wheel bearing replacement question
Postby Glycerine » Wed May 30, 2012 9:13 pm
just in the process off doing this,
but i need a couple of torque specs if anyone can help??
the actual hub nut.. the one that bolts the hub/spindle through the bearing.
and the 4 bolts that hold the hub/bearing assembly to the carrier/suspension arm
(this is on a rear brake disc, non abs vehicle)
Thanks
Glycerine
Postby Crucible » Fri Jun 01, 2012 12:33 am
Just tight. I wouldnt worry too much about torque settings.
Crucible
Real Life Mechanic
