Clearing Airbag warning light after removing dashboard
Postby thegreatestben » Wed May 16, 2012 10:54 pm
Hey, so in my stupidness I have figured out the hard way that if you remove the dash from a crown the airbag light stay on.
I have found the procedure to clear it, which is outlined here:
http://www.lexls.com/tutorials/lighting ... light.html
Same as LS/GS/SC lexus/toyota models.
Has anyone successfully done this before?? Apparently as a white guy I have no rhythm and couldn't get it to work. I'm going to buy a on/off/on switch from work tomorrow to make this more accurate. But failing that is there any other option?
Would a dealership have a diagnostic connector to clear this?
Was in search of bad caps in the dashboard, didn't dig deep enough so will need to take another look anyway...
thegreatestben
Postby Dell'Orto » Wed May 16, 2012 11:09 pm
T69 wont plug in?
Postby Lloyd » Thu May 17, 2012 12:59 am
Disconnecting the battery for half an hour doesn't work? Anyone with a half decent scanner should be able to clear it, dealer or not.
Postby thegreatestben » Thu May 17, 2012 1:11 am
Stores in memory apparently disconnecting battery does jack! Wasn't sure if scan tools come with that Particular connector...
thegreatestben
Re: Clearing Airbag warning light after removing dashboard
Postby RUKI » Fri Jun 01, 2012 9:21 pm
thegreatestben wrote:Hey, so in my stupidness I have figured out the hard way that if you remove the dash from a crown the airbag light stay on.
Looking at your link - they are little bit unclear.
My knowledge suggests that after connecting TC to AB on DLC1 -> IGN -> "ON" and waiting for 6 seconds then you connect Tc / Ab to E1 (which is ground) 3 times. I am just about to make this weekend convenient jumper wire with 3 pins and two fast knobs to do the trick.
Send me a message if you still did not get any help yet.
RUKI
Postby thegreatestben » Tue Jun 05, 2012 10:52 pm
I got it sorted, I think it was my timing. In the end I used the stopwatch function on my iPhone. Got it first pop. Made a switch using an on/off/on switch.
thegreatestben
