tig welder gas setting
Postby sk1dlet » Tue Jun 12, 2012 6:51 pm
hey guys i recently brought a cheapish tig welder to do a bit of fabricating
trouble is i seem to go though a bit of gas, im only using disposeable bottles at the moment through a mini regulator that only has a pressure gauge on it
roughly what psi should i be running it at? or am i better off bitting the bullet and buying a proper bottle and regulator?
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby Bling » Tue Jun 12, 2012 6:59 pm
The small cylinders are certainly a lot more expensive to run than a bigger cylinder. But check you don't have leaks on anything. I have never used a small cylinder so can't comment on how many minutes welding you'd get. But you should be able to work out a rough idea with the below calc.
Try this to work out gas pressure needed
http://www.millerwelds.com/resources/ca ... ulator.php
Postby evil_si » Tue Jun 12, 2012 7:35 pm
You really need a proper reg, with lites per minute
Mild steel and stainless 2-4lpm
Alloy 4-8lpm
I know of a full G size (big) argon bottle for sale $300
evil_si
Postby Stott69 » Tue Jun 12, 2012 8:16 pm
Don't you just rent bottles off BOC?
Stott69
Postby evil_si » Tue Jun 12, 2012 8:46 pm
Stott69 wrote:Don't you just rent bottles off BOC?
Not if you can help it
evil_si
Postby Bling » Tue Jun 12, 2012 9:31 pm
evil_si wrote:I know of a full G size (big) argon bottle for sale $300
Damn that's cheap! Especially for an argon cylinder.
Postby sk1dlet » Tue Jun 12, 2012 10:23 pm
oh ok cheers si how much do one of those bottles cost to fill?
98 RS200 ALTEZZA
sk1dlet
Postby Adoom » Tue Jun 12, 2012 10:52 pm
sk1dlet wrote:oh ok cheers si how much do one of those bottles cost to fill?
A D size argoshield is $90 to fill at BOC.
Adoom
Postby cat007 » Tue Jun 12, 2012 10:57 pm
I have an account with Supagas and get my bottles through Ezitools on the shore - each bottle is about $16 a month - regardless of size....although I've only ever had D and F sizes.....perhaps G sizes are more....
I found the D size ran out very quickly.
Postby Stu- » Tue Jun 12, 2012 11:01 pm
Cheap bottle man!
BOC are expensive for rentals but their roll up and swap the bottle idea is very handy (we have 8+ g size argon bottles). I use Supagas for the home setup but have had some major frustration with delays in bottle filling (they have to go to Hamilton).
Project Thread
Stu-
Postby Adoom » Tue Jun 12, 2012 11:46 pm
cat007 wrote:I have an account with Supagas and get my bottles through Ezitools on the shore - each bottle is about $16 a month - regardless of size....although I've only ever had D and F sizes.....perhaps G sizes are more....
I pay about $15 a month for each D bottle. The guy at boc said it was roughly an extra $1 for each size you go up.
But a G bottle is HUUUGE. PITA when you want to move the welder.
Adoom
Postby sk1dlet » Wed Jun 13, 2012 9:11 am
Well renting doesn't seem like a to be a bad of a option,there's a local engineering place that is a supagas outlet here in te aroha I may have to see what there prices are? And weather it's roll in and swap or if they fill them
98 RS200 ALTEZZA
sk1dlet
