Seats,brackets and seat rails?
Postby TOYO-GT-T » Thu Jun 28, 2012 9:29 pm
I have a Toyota Vitz RS and are looking for some feedback on good aftermarket or factory spec replacement seats.
After installing the Tein springs and rear sway bar (going in tomorrow) the car feels like its on rails and will feel more so by tomorrow.
Only problem.....
Now I am starting to get "human body roll" and it will probably be even worse at track days. The factory sports seats do have a slight hugging fit,but not enough to keep you one place.
There are loads of seats around on trademe, whats a good replacement and how do you fit them as I am sure all rails,seat bolt holes ,floor holes, bracket width and length are different for each car, and I certainly don't want WOF issues. :D
Past:
Ex 1990 Toyota MR2 GT
Ex 1997 Toyota Caldina GT-T
2001 Honda Euro R
2001 Toyota Vitz RS 1500cc
TOYO-GT-T
Postby 1I1 » Thu Jun 28, 2012 9:39 pm
I found recaro SR3 to be an awesome option. Miles better than an ordinary stock seat in terms of laterial support but still comfy and easy to get in/out of on a day to basis. Get some bride or recaro rails off yahoo auctions/upgarage etc and you're sorted. Rails will probably be dearer than the actual seat :lol:
TRD Clicky >>Here
1I1
Postby TOYO-GT-T » Thu Jun 28, 2012 11:44 pm
1I1 wrote:I found recaro SR3 to be an awesome option. Miles better than an ordinary stock seat in terms of laterial support but still comfy and easy to get in/out of on a day to basis. Get some bride or recaro rails off yahoo auctions/upgarage etc and you're sorted. Rails will probably be dearer than the actual seat :lol:
Thanks for that, are they the Japanese auction sites? I assume they just marry up with the SR3's and bolt on in? sounds great :D
Past:
2001 Honda Euro R
TOYO-GT-T
Postby RobertC » Thu Jun 28, 2012 11:52 pm
yes they are Japanese auction sites. I would recommend Ewan from Hayatonka for sorting out the buying process and postage.
Yes you will be able to get a bolt up rail.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby Mr Ree » Fri Jun 29, 2012 12:14 am
You often find SR3's on trade me too so have a look about before buying off shore.
wak thud gush!
Mr Ree
Postby RobertC » Fri Jun 29, 2012 12:29 am
I think 1i1 meant to just get the rail from japan. Seats are much cheaper here.
bride rail that will fit an sr3
http://www.upgarage.com/upgarage/stock/1/2/1204123005433/123
recaro rail that will fit an sr3 (wont need certification) but is a LH. gives you an idea of what to look for
http://www.upgarage.com/upgarage/stock/1/2/1110176007952/176
RobertC
Postby 1I1 » Fri Jun 29, 2012 9:50 am
Yeah theres plenty of seats on TM at the moment.
TRD Clicky >>Here
1I1
Postby TOYO-GT-T » Sun Jul 01, 2012 10:02 am
http://www.trademe.co.nz/Browse/Listing.aspx?id=489142897
Would this be what I am after, I could then order the passanger side ex Japan.
I assume a recaro or bride seat will bolt straight up and rails will bolt straight in line with factory bolt points.
Past:
2001 Honda Euro R
TOYO-GT-T
Postby RobertC » Sun Jul 01, 2012 3:04 pm
TOYO-GT-T wrote:http://www.trademe.co.nz/Browse/Listing.aspx?id=489142897
No, a recaro will not bolt to that rail.
That rail will fit BRIDE: EURO2 series, DIGO series, Old BRIX, ERGO old, XAX old and REVS old.
If you compare it to the ones above I posted. You will notice that the one on trademe has members running across ways for the seat to mount to.
Where as the ones I posted doesn't. The ones what don't have the members, the seat bolts directly to the rail. And the rails are further apart to suit a recaro.
RobertC
