AE111 20v Blacktop Mods... HELP NEEDED
Postby 1I1 » Tue Jul 31, 2012 12:09 pm
4th gear at 60km/h is about 3,000rpm with a C160
TRD Clicky >>Here
1I1
Postby Bling » Tue Jul 31, 2012 1:39 pm
That sounds more reasonable.
Postby gt4dude » Tue Jul 31, 2012 2:59 pm
Yeah, You're right actually, it's not as silly as I remember it
http://www.youtube.com/watch?v=dz0MVMFm ... re=related
Does the 5 speed also cruise 60 @ 3000 in 4th???
I'm used to cruising at 2000 rpm, guess I exaggerated when i spoke before
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby 1I1 » Tue Jul 31, 2012 3:32 pm
4th gear on a C56 @ 3000rpm should be 75km/h
FWIW - 8,000rpm in 4th:
C56 201km/h
C160 169km/h
TRD Clicky >>Here
1I1
Postby jacobrjett » Tue Jul 31, 2012 3:37 pm
yeah i do notice i need to change into 5th when trying to max the speedo, where in my ae101 with the 5 speed it would only be 4th. not that i ever do :lol:
jacobrjett
Postby RS13 » Tue Jul 31, 2012 9:50 pm
FatBzg wrote:What Aftermarket ECU would you reccommend?
Actually, forget I said that. If you're paying to get it done, you won't get much change from $2000 for a decent ECU installed and tuned properly. Not really cost effective given that you don't have any internal modifications. Blacktop 4AGEs are quite well-tuned from factory and there isn't much more you can squeeze out of it without spending huge money, even more than what the car is worth.
It totally depends on how far you want to take it. If you're working with a small budget but want a solid streetcar or to get into trackdays (and the car is your daily driver) the best place to start is upgrading brakes and suspension. No point making more power if you're going to understeer everywhere and get outbraked by Daihatsu Miras around corners.. decent pads and fluid are a couple of hundred, I notice you're shopping for lowered springs too which is a good start. You want it as stiff as possible so shop around for decent front/rear strut braces, also look at replacing any old, worn out bushes etc with new or aftermarket ones. Decent rims/tyres are also well worth it in terms of handling gain.
Your car was designed to run on higher octane fuel than that in NZ, so run 98 and reset the ECU occasionally, its' simple to do and has a noticeable difference in power over running 95 or 91.
RS13
Postby Luke - BZG » Tue Jul 31, 2012 10:51 pm
I can't believe we have another 2 page thread of "black top mods help"
Luke - BZG
Postby Mr Ree » Wed Aug 01, 2012 11:10 am
lets make it three ;)
wak thud gush!
Mr Ree
Postby Distrb » Wed Aug 01, 2012 11:13 am
best thing you can do to a blacktop is remove it from the car completely and replace it with a B18CR
Distrb
Regular Poster
Postby 1I1 » Wed Aug 01, 2012 11:19 am
I take your B18CR and raise you a K20A
TRD Clicky >>Here
1I1
Postby Shrike » Wed Aug 01, 2012 11:53 am
Something about a honda engine in a toyota just feels so wrong
Whats your budget theres heaps you can do but its costly
as said before do all the handling mods first then look at weight reduction after that if your wanting to keep it na
With a factory ecu id stick to
Headers
Exhaust
Cams (either new from kelford or get them reground from franklin) (280 max on stock ecu off the top of my head)
adjustable cam gear on exhaust side for overlap
fuel mixer to lean it out as they run rich
cold air intake
chuck on dyno to check afrs
retard timing 2 degrees for more bottom end torque (confirm on dyno)
thats without opening the engine
Then theres thinner headgaskets 0.8-0.6mm
Headwork ie port+polish
higher comp pistons
stronger rods + bolts
but it gets costly
you could build a 7age yourself for roughly 2-3Kish
7a block
blacktop pistons got from factory engine
gasket kit
rodbolts
bearings
ecu (ms3 is an option)
hi comp 7age would be fun :p
again whats your budget
Shrike
Postby Lith » Wed Aug 01, 2012 3:19 pm
Shrike wrote:Something about a honda engine in a toyota just feels so wrong
I'd say the only thing wrong about it would be how driving an AE111 with a 4AGE in it would seem if you'd put a Honda motor in one and had been driving it around for a few weeks.
But in terms of being a purist I could see how wanting to stick with what it came with and making it grumpy would appeal.
2007 Mazdaspeed Axela
Lith
Postby Shrike » Wed Aug 01, 2012 3:47 pm
Changing to a
7age
2zz
1zz
2azfe
Etc all toyota motors that would be fine
(I think the 3s/5s engines are heavy pigs so im bias)
But I get the reasoning for the honda engines there easy to get and cheap to get parts for
Shrike
Postby jacobrjett » Wed Aug 01, 2012 4:12 pm
Id proudly have an ae86 with a b18c.
jacobrjett
Postby GDII » Wed Aug 01, 2012 4:15 pm
jacobrjett wrote:Id proudly have an ae86 with a b18c.
Only problem is the engine spins the wrong way for RWD. Unless you like to drive in reverse very fast.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby jacobrjett » Wed Aug 01, 2012 4:22 pm
tell this guy:
http://www.driftworks.com/forum/drift-cars-sale-private-sales/149932-my-2-litre-vtec-powered-ae86.html
or is that engine different? (i know its a different engine but the way its designed i mean)
edit: nevermind just remembered the s2000 is rwd.
i didnt think of that but i have noticed that everything is back to front on fwd hondas so your right.
jacobrjett
Postby Shrike » Wed Aug 01, 2012 4:58 pm
3sge from a altenza (alloy block from memory so weight isnt as bad)
1jz
2jz
3rz
All engines Id rather have over a honda
if you want a honda engine buy a honda
Shrike
Postby dnalunchie » Wed Aug 01, 2012 5:39 pm
they thing to remember about the blacktop engine is once you have the basic Intake exhaust and cams everything else is going to cost big money.
the first 30hp. cheap
the next 30hp.... heaps
EX:89 RS and GT Legacys, 90 EF9 Civic, 95 Integra R, 95 AE101, 90 ST185, 88 Accord, 87 3rdoor and 5door Swift hatch, 91 Pontiac Lemans, 80 Liftback Celica, 95 Hornet 250
Current: 90 3sfe Corona
dnalunchie
Postby Grrrrrrr! » Wed Aug 01, 2012 6:14 pm
Altenza? is that what you get when an altezza rearends a mazda atenza? :D
Pretty sure every A and S series motor is a cast iron block, later 3s motors had alloy sump casting and stuff, but block is still good old iron.
2zz was first toyota performance motor with ali block I believe.
Grrrrrrr!
Postby rollaholic » Wed Aug 01, 2012 6:29 pm
dnalunchie wrote:they thing to remember about the blacktop engine is once you have the basic Intake exhaust and cams everything else is going to cost big money.
doubling the factory output is cheap?! :P
honda do better NA 4 cylinder engines than any other manufacturer i can think of by a long stretch, its simple really :) (not counting bikes :P)
if you want straight line speed, you have the wrong car. if you want to go fast round corners well... theres alot more stuff above power on the list of things that help.
Users browsing this forum: Bing [Bot] and 23 guests
