Tial WG leaks air from pressure reference ports
Postby gt4dude » Mon Aug 06, 2012 7:35 pm
I hooked up the bottom port to an air compressor, some air bleeds from the top port, but alot leaks out underneath
is this normal? it still boosts around the spring pressure, maybe a tiny spike or 2 but not major
not as major as the air leak sounds anyways
http://youtu.be/E_Hc3EBoo1A
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Mon Aug 06, 2012 8:20 pm
no good
just tested .8bar springs its spiking to 1.3bar in 3rd gear and 1.1bar in 2nd
on .6bar springs it holds .6bar ;S
when i use the tap on the .6bar springs i can get to .85bar steady, but another 1/4 turn after that shoots straight to 1.3bar
200AWKW / 370NM
gt4dude
Postby iOnic » Mon Aug 06, 2012 8:31 pm
Genuine Tial? Sounds like a leaking diaphragm and a leaking valve stem. What model is it? Tial sell replacement parts.
Postby gt4dude » Mon Aug 06, 2012 8:37 pm
Yeah 2 months old from NZ performance, should I hit them up and send it back or is it normal to leak ????
200AWKW / 370NM
gt4dude
Postby iOnic » Mon Aug 06, 2012 8:42 pm
No it's not normal at all. I would contact him if it's still under warranty and have it tested and replaced.
Postby matt dunn » Mon Aug 06, 2012 10:10 pm
Leaking through the shaft is normal and does not affect operation.
Is you apply pressure to the bottom port and get air coming out the top port is not and is a sign of a faulty diaphram.
i presume that you are not blocking off the top port
then applying pressure to the bottom one?
as that wont test it.
Postby gt4dude » Tue Aug 07, 2012 3:42 am
im just applying pressure to the bottom port, and its coming out the bottom and the top port both
i see no sign that i have pinched the diaphragm or anything like that
i actually thought the top port was supposed to vent to atmo a little bleedoff
200AWKW / 370NM
gt4dude
Postby Bazda » Tue Aug 07, 2012 9:34 am
No, you hook up your vacuum line from the inlet mani to the bottom port.
Then you hook the controlling pressure line into the top. Usually comes from your boost controller.
