sergei wrote:Basically the "drain" (earth) should be equal (or more) to the "supply".
If not it will heat up the weakest link, and will use paths that not meant to (eg: it will try to go through random sensor earth and blow the ECU in worst case).
mlewis wrote:My battery is in the boot so was going to hook up some wires ranging from head, block, gearbox to different parts of the chassis? would that work or do they need to get to the negative terminal?
