mods for a entry level clubsport car
Postby DexGT » Tue Sep 18, 2012 11:54 pm
BigDon wrote:I cant see if you have a catch can in there under the bonnet but if you do make sure it is big enough to comply with MSNZ rules or revert to factory piping. From memory if you have a catch can then
Engines up to and including 2000cc need to have a minimum of 1 litre catch tank capacity
Engines exceeding 2000cc shall have a min of 2 litre catch tank capacity
I cant remember if the above engine capacity is pre or post the equivalence factor being applied.
It is just on straight engine size , no equivalence factor is applied in this rule 8)
DexGT
Postby LEAKER » Wed Sep 19, 2012 7:06 am
No catch can so sweet there thanks.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby TTEETT » Wed Sep 19, 2012 9:53 am
Looks good, sounds like you have a good plan!
Keep an eye out for or make a skid plate to put on the front to shield the Intercooler if you can, you ideally want it above something solid, you may find yourself knocking the pipes off and bending the mounts often.
fangsport wrote:
BZG|Bling wrote:What if the system failed and he didn't have the extinguisher? You know who would be the ones in hot water if someone was injured as a result. Hence blanket rule I guess.
what if you done repairs to the car and forgot to put the onboard extinguisher fuse back in??
happened to Hayden Paddon's Evo4 when it burnt. apparently.
Yep, good point's, you would be gutted if that happened. Its not my car, he just mentioned that when we were going over the extinguisher rules.
Either way I will do whatever they ask as I want to race and would not argue over something like that.
TTEETT
Postby matt dunn » Wed Sep 19, 2012 8:19 pm
LEAKER wrote:No catch can so sweet there thanks.
IMO a catch can would be one of the better performance mods to do,
especially on a car with a knock sensor and a standard ECU.
You would be amazed at how much HP you loose from having the oil vapours going back into the engine.
Postby LEAKER » Thu Sep 20, 2012 5:41 pm
Sweet cheers man, ill stick that on the list.
LEAKER
Postby Pelo » Fri Sep 06, 2013 3:39 pm
Thread revival: Can this be made in to a sticky please? Some very helpful information here :)
Pelo
Postby Dell'Orto » Fri Sep 06, 2013 9:34 pm
FAQ'd right here viewtopic.php?t=91372 8)
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 4 guests
