Electronic speedo.
Electronic speedo.
Postby Adoom » Wed Sep 26, 2012 6:50 pm
So THE STARVIA has the factory starlet mechanical speedo. It is currently cable driven from the CA18 Nissan gearbox.
It reads 20% fast. The numbers only go up to 160kph, a bit useless if I want to know how fast I am going on the track...
I am replacing the mechanical drive thingy with an electronic sender, it's a straight swap.
I can wire this sender into the Link G4 so it knows how fast I am going, and it can log it too.
But this means the old speedo will no longer work...
If I plug a laptop into the link I can have a readout of the speed etc etc. But it's not ideal for normal driving or for WOFs.
The link can drive an electronic speedo with a pwm signal.
The question is, what electronic speedo can I use that is really cheap or free?
Ideally the doner speedo would not be part of a cluster, or be easy enough to dismantle and hack into the starlet cluster.
Adoom
Postby Shrike » Wed Sep 26, 2012 8:57 pm
http://mlracing.co.nz/magento/index.php ... meter.html
$125 is pretty cheap tell him your from toyspeed and that shrike sent you and Alex will probably give you a discount
Shrike
Postby Adoom » Wed Sep 26, 2012 9:24 pm
Shrike wrote:http://mlracing.co.nz/magento/index.php/meters-and-gauges/80mm/autogauge-smoked-80mm-stepper-gauge-speedometer.html
Looks far too flash :P Might go to Pick a Part and see if I can find something I can use.
On the subject. So I pulled out the mechanical drive thingy. It has a 24mm gear.
The electronic sender has a 28mm gear. but it just went straight in.
What gives? How can it engage? Am I being thick? :? :?
I've attached a multimeter(using the beep setting) to the wires and turned the gearbox output shaft, the multimeter beeps about 3 times for each revolution, so the gears are engaged.
Adoom
Postby Soiled » Wed Sep 26, 2012 11:38 pm
http://www.merlinmotorsport.co.uk/p6217 ... _info.html
You can find them cheaper second hand through ebay etc.
Soiled
Postby wde_bdy » Wed Sep 26, 2012 11:48 pm
Put a Nissan dash in?
Callum
wde_bdy
Postby gasman » Thu Sep 27, 2012 12:22 am
i did a similar thing on a mates car which had a mechanical speedo but went to a electronic sender unit.
i just grabbed the guts of an electronic speedo that had the same sweep as the factory layout and made it fit into the factory dash. worked and looks stock as a rock.
"What can possibly go wrong?"
gasman
Postby Adoom » Thu Sep 27, 2012 10:32 am
gasman wrote:i did a similar thing on a mates car which had a mechanical speedo but went to a electronic sender unit.
This is the plan. I shall visit Pick a Part and pull some dashboards apart.
Adoom
