Map 4agze
Map 4agze
Postby evil_si » Sat Oct 13, 2012 1:08 pm
Ok, out of curiosity what will a 4agze do when map sensor is unplugged?
Anything? Will it idle, will it die when trying to rev?
Reason i ask is i Looked at a car recently
Thing would idle perfect, but wouldnt run above idle, would cough and die,
Uplugging the map sensor made no difference at all.. Neither to problem or idle
The loom looked like it has been played with a bit, and i didnt have the time to verify the maps pin outs and power supply were correct.
evil_si
Postby iOnic » Sat Oct 13, 2012 1:19 pm
It should run/idle but cough/splutter/die when it comes on boost which I suppose is straight away on a GZE?
My Mrs Starlet had an unplugged MAP sensor and would run fine below boost but as soon as you tried to build boost it would shudder/cough/die etc. Took forever to work out what it was.
Postby l1ttle_d3vil » Sat Oct 13, 2012 3:25 pm
Sounds about right, but sounds similar to a stuffed TPS too...
Re: Map 4agze
Postby LEAKER » Sat Oct 13, 2012 4:05 pm
evil_si wrote:Thing would idle perfect, but wouldnt run above idle, would cough and die
Failling Fuel pump can also cause this sort of thing
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby evil_si » Sat Oct 13, 2012 6:47 pm
Sorry guys not after a diagnosis,
i want to know what happens when a map is unplugged on a gze,
I cannot recall ever unplugging one in the past to see what happens
evil_si
Postby themaleman » Wed Oct 17, 2012 6:12 pm
engine check light comes on. no boost. runs like crap
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
