Stott69 wrote:Whats your ducting system? Is it straight and unrestrictive? Maybe a inline fan to push air on the brakes during lowwer speeds?
Mr Ree wrote:Stott69 wrote:Whats your ducting system? Is it straight and unrestrictive? Maybe a inline fan to push air on the brakes during lowwer speeds?
The fan would just become a restriction when airflow was needed most though, mate.
Stott69 wrote:Mr Ree wrote:Stott69 wrote:Whats your ducting system? Is it straight and unrestrictive? Maybe a inline fan to push air on the brakes during lowwer speeds?
Not if set up right, or whats the point of a turbo? A fan would be able to push air down the ducting at lowwer speeds when air force on the intakes is low. I'm a hvac tech so deal with fans n ducting day to day, selecting the right ducting and fan is the same in a way as turbo n intercooler.
Mr Revhead wrote:Manual conversion
fxgt race wrote:As I said it will evaporate when it hits the disk, not in mid air, theres no need to over complicate the concept with timers and flow rates. Its a simple setup.
RS13 wrote:Mr Revhead wrote:Manual conversion
Its' automatic? With little or no engine braking, you're asking pretty big things of your brakes on the track.
