92mr2paddy wrote:why not buy proper ride height adjustable suspension?
92mr2paddy wrote:yeap ive read your post but the cusco's only have spring adjustment so when you wind it down u also loosen the spring making it more bouncy? yea getting a cert is downside
Lloyd wrote:No real downside apart from the possibility that they wont get the height exactly right for what you want. And being that you're aiming for such a small change I would be surprised if its bang on what you want. And that they may settle a bit over time and be lower than you cant, then you cant just wind them up like you could with adjustable.
escortman wrote:And shocks might not be able to cope and constantly bottom out. Youd be better off looking for coilovers that are height adjustable seperate to the sping platform, hsd in my supra are like this
Lloyd wrote:Sure, but bear in mind that it is still a spring. Saying you want it 20mm lower when loaded, then sending a bare spring to them could get it 10mm lower, or could get it back 30mm lower. Shorter shocks should be fine, the piston shouldn't bottom out if things are shortened, but you may end up hitting bump stops.
xsspeed wrote:From what I understand the spring rate will be way less (ie less stiff) after compressed. You'd be better off getting some springs made by the likes of Snell's to the specs you want.
If not I would be looking at some brand of super lows and shortened shocks if required.
BZG|Bling wrote:Why not just save your pennies and buy some of Bazda's coilovers. I'm sure he can set up a pair to suit your needs. 2nd hand coilovers is either going to end up in very good luck and get a good result, or just money done the drain.
Dell'Orto wrote:Get custom made springs if you don't want to save for coilovers, they're far better an option than compressed ones. Can get any height you want, or even specify a rate.
escortman wrote:Yeh when you compress springs they normally go softer, and shortening shocks only help keep the springs captive at full travel they wont do anything to stop them bottoming out or hitting bump stops.
Have you thought about getting different spring rate for the coilovers?
BZG|Bling wrote:I can see this thread ending up like the other one.
Unless you are going to chop down the strut housings, compressed super lows are just going to end in fail imo. Most of the above ideas end up in cert territory anyway so I see no gains from 'cheaping out'.
Kiwi-Corolla wrote:What sort of ballpark figure would I be looking at for custom made springs? Compressing my current Super Lows is going to cost $50 a spring, so $200 for the set. If the price is somewhere near that figure to get a set of custom made springs made then it might be worth considering
