jaypines wrote:did you try to swap the whole throttle body as well? other things to check: injectors, catalytic converter blocked?. also try compare maf output waveforms/voltages vs injection duty cycle?
bones on bikes wrote:Didnt swap throttle body but ICV has been out cleaned etc.
Has no cat only one rear box muffler
Lith wrote:Had a quick Google and it looks like it is a narrow band. Does it read that voltage at idle etc? If so then there is something wrong with how your O2 sensor is working or passing it's signal to the ECU , imho. It should be reading around 1volt at idle, any lower will make it think it is rich and it will try and lean it out and vice versa for if it is above 1 volt.
It sounds like it keeps leaning it out and never succeeds in getting it to it's target of 1.
Could be wrong but it would be where I would put my focus
bones on bikes wrote:The thing that no one understands is why it stalls when it does (driving conditions) and doesnt seem to stall at idle.
matt dunn wrote:
Their operating range is 0.25V to 0.85 volts,
with 0.5 volts being Lambda 1.
Under normal conditiond withe enge engine held at 1500rpm no load,
the sensor should fluctuate between under 0.4v and above 0.6v
at least 6 to 8 times a second.
A constant voltage from the 02 sensor is not normal,
and they should read close to .8V if you give it a shoefull,
and then drop to around 0.3v when you lift off.bones on bikes wrote:The thing that no one understands is why it stalls when it does (driving conditions) and doesnt seem to stall at idle.
No speed sensor signal will cause this under quick deceleration,
but I presume you have it working as they run like shit without it.
bones on bikes wrote:The readings i am getting are off a generic scan tool so i am getting a semi stable voltage (I dont have access to a scope so cant really see what is happening within a second)
Are we talking engine speed or vehicle speed? it is intermittent when it cuts out and is not always under rapid deceleration normally just backing off whilst cruising at 100kms or so.
When you say it cuts out backing off at 100kms,
it is manual? as the engine should stay turning,
does it no go when you put the accell back down or are you pusinh in the clutch and it stalls???
Cant really see what you are saying?
matt dunn wrote:Their operating range is 0.25V to 0.85 volts,
with 0.5 volts being Lambda 1.7
There is one way to eliminate the O2 sensor: just have it disconnected.
Yes it will bring on CEL and will record a code, will also run in open loop mode.
crispy'86 wrote:Not sure if you stated you checked the tps output and set-up? Also does your road car still run the cat still. Your race car doesn't run the cat? Does it have pre and post cat converter O2 sensors? If it does run both i suspect the post cat sensor will always show up as a constant voltage saying it measures after the cat.
also may pay to check the injectors if they leak, clamp off the return line and leave it sitting and check presure drop. Or alternatively remove the inlet manifold and check the injectors for leakage. Does the scan tool have a graph on it and can check different readings. i.e afm and O2 sensor? Can it perform an actuation test, may pay to try this too to give you an idea
