Shrike wrote:What manual boost tap did you order
I had issues with a generic one even after the mod so it runs the same boost in all gears
Main problem with manual taps is they spike
sergei wrote:The first question you should be asking yourself, is why is it running 7psi and not 10psi?
It looks like T-VSV is off, either disconnected, blocked or not being activated by ECU (limp mode?).
Alternatively your boost gauge is inaccurate, or setup incorrectly.
My suggestion: make sure it is running correctly and leave it alone, unless you are prepared to spend more money than the car costs....
FSRRM wrote:XS1V wrote:Bye bye ceramic wheel
Brad
Aw man, whaatttt. lol should I get the GFB Atomic Boost controller?
FSRRM wrote:sergei wrote:The first question you should be asking yourself, is why is it running 7psi and not 10psi?
Intense. Ok, So, one thing I thought that the VSV was working is when it was restricting 1st and 2nd gear to 5PSI. then 7PSI in third.
I ran the Boost Gauge off the intake manifold(The one that was blocked off)
sergei wrote:FSRRM wrote:sergei wrote:The first question you should be asking yourself, is why is it running 7psi and not 10psi?
1st and 2nd gear is not restricted to low boost. There isn't enough load (or time) in 1st and 2nd gear to simply generate high boost.
Hold the brakes in 1st gear and you will see full boost (and smoke from the brakes .
It is simply a myth.
You will need to check if your TVSV is operating, boost gauge could be also inaccurate (the "high" boost on ST185 is around 8-11psi). I can confirm exact figures once I get home and check the repair manual...
On factory CT26 you will not achieve anything dramatic by raising boost. It will just generate more heat and overall will be slow as shit.
EDIT: the manual specifies overall pressure between 0.5-0.83bar (7.1-11.8psi), which I assume means the 0.5bar is low (with TVSV off) and 0.83 is high (with TVSV on).
Al wrote:Dell'Orto wrote:Put a chinese downpipe on it, you'll get plenty more boost
I can sell OP a Berk downpipe, only catch is its attached to an MR2.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 31 guests
