ST215 3SGTE into ST185
Postby Rob » Sat Oct 13, 2012 10:40 pm
Hey team, just picked up an ST185 with a 215 motor in it. It turns over but won't start. I've been searching the web all afternoon but can't find a wiring diagram for a 215, already have a 185 one but this thing looks like a butcher had a go
Any help would be greatly appreciated
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 7ishNZ » Sun Oct 14, 2012 6:57 pm
7ish
7ishNZ
Postby Rob » Sun Oct 14, 2012 9:28 pm
Thanks pal, I'll see what I can make of it tomorrow night
Rob
Postby Rob » Sat Oct 20, 2012 2:30 pm
wheres the starter relay in the 185?
Rob
Postby Rob » Sun Oct 28, 2012 4:09 pm
Anyone know the size of alternator belt needed without aircon???? Can't find mine and don't have the original.
Rob
Postby 7ishNZ » Tue Oct 30, 2012 10:52 am
Just run a piece of string round the pulleys and measure the length... A 3 or 4 ribbed belt will have a 3pkxxx or 4 pkxxx where xxx is the length in millimetres.
7ish
7ishNZ
Postby gt4dude » Fri Nov 02, 2012 2:16 pm
i went to supercheap and checked out the range of bosch belts for aircon removal, they didnt have the size i wanted,
toyota have a 5pk1010 belt with the P/N 99365-21010
if you need a ribbed tensioner pulley the P/N is 16603-88360
this is for ST205 3SGTE AC removal.
I managed to do away with the entire bracket and pulley alltogether and tensioned it by swivelling the alternator and locking it in with a wedge
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby Rob » Sat Nov 17, 2012 10:47 am
So got this bad boy running, gotta pull out the fan switch and test it, as the fan goes constantly. Also I'm running full boost at idle according to the factory boost gauge (maybe a wrong wire in there)
Anyone know anything about a tacho adaptor? I've looked it up online and it appears they're all the same, but I would like to get the parts and do it myself as its only four diodes and four resistors. Just wanna know if 400v 100Kr and 400v 1A diodes will be for all vehicles?
Cheers for that belt knowledge I found the one that came with the car eventually in front of my eyes
Rob
Postby 85AW20v » Sat Nov 17, 2012 11:55 am
With the fan running all the time, you probably need to bridge the terminal that the aircon pump was plugged in to. Seems to be a common thing on Toyota's with the aircon removed.
See ya
Simon
85 MR2 20v
85AW20v
Postby Rob » Sat Nov 17, 2012 2:46 pm
The fan is run through a funny looking oval plug which is on the aircon piping. What I did on my other car was loop the wires furtherest apart and it was fixed, so then I traced them back to the main fuse box by the battery and have just run them straight from there on this second car. Problem was dodgy fan switch. Luckily hoarding unused parts from Dodsons while fitting Motors has rewarded me once again with a freebie and my fan is now fine.
Now the full boost at idle beef......................
Rob
Users browsing this forum: Majestic-12 [Bot] and 32 guests
