steroidcontaskie wrote:Hi all
I have a issue with my current 2jzge turbo build. I checked the timing of the engine and it was about 30 degrees BTDC. I adjusted it the most I could, but the distibutor cap hits the turbo when it is 17 degrees BTDC, so that is my limit of adjustment (factory is 10 BTDC).
Engine idles at 700 rpm, and is fine if the A/F is between 9-12.5 but if I lean it out to 14 or so, it gets a miss about every 5s. Vacuum is 22mmhg.
I have 2 questions,
1. Would it be ok to put a 7 degree timing retard across the entire rev range using my piggy back ECU to make up for the 7 degrees too adavanced the timing is on the distributor?
2. Would the timing being too far advanced be a potential cause of the engine miss?
Was thinking I could try the 7 degree retard and then see if it fixes it, if that fails, try new spark plugs.
Edward
steroidcontaskie wrote:...all the rich running is fouling them up and I thought I should put some new copper ones in for tuning.
Users browsing this forum: Bing [Bot] and 30 guests
