DVSMOTORSPORT wrote:If it is the w/bearing, try adjusting your axle nut, if that doesnt work then you need to replace the bearing.
iOnic wrote:Edit: the hairdresser is on to it
rollaholic wrote:DVSMOTORSPORT wrote:If it is the w/bearing, try adjusting your axle nut, if that doesnt work then you need to replace the bearing.
by adjust he means, crank the hell out of it with a 2m bar
jealous imo
