AVS Boot Out / Boot Release
Postby BZG Wagon » Wed Dec 26, 2012 8:11 pm
The AVS alarm in my Terrano has a wire labled 'boot out'. I want to hook up the alarm so the rear boot window unlocks (+12v) however when I press the boot release (left button on the remote for 3 seconds) nothing happens other than the alarm chirping a couple times.
Is anyone familiar with AVS installs and what I need to do to get this working?
BZG Wagon
Postby Dell'Orto » Wed Dec 26, 2012 8:27 pm
How is it wired in? Output to a relay to the window motor I take it?
Postby BZG Wagon » Fri Dec 28, 2012 10:11 pm
The alarm or the boot?
...not sure - are you saying I need to wire +12v to the alarm, to provide power to the boot release?
BZG Wagon
Postby Dell'Orto » Fri Dec 28, 2012 10:14 pm
No, more asking how is the alarm triggering the boot release? Is there an output directly to the boot release motor or does it trigger a relay?
Postby BZG Wagon » Fri Dec 28, 2012 10:31 pm
Oh - sorry.
There is a an output wire labled "Boot Out" coming from the alarm, running 0.30v when connected to the multimeter. When I hold the boot release button for 3 seconds the alarm chirps twice and the voltage jumps to 0.60v for a few seconds, before dropping back to 0.30v.
From what I gather from the user manual (not the installation manual) I do not require a separate relay / part to trigger the boot. I was hoping / expecting the 'boot out' to spike to 12v, which would have triggered the existing boot relay.
BZG Wagon
Postby Dell'Orto » Fri Dec 28, 2012 10:39 pm
Right, that makes sense. Obvious question - but you have checked to see it is actually connected to the relay?
Postby Grrrrrrr! » Fri Dec 28, 2012 10:40 pm
0.3 to 0.6 volts sounds like it is a transistor being turned on to sink a current. Try putting a largish (say 1K ohm) resistor between 12V and the alarm output and seeing if it then becomes 12V, pulling down to ~1V when you activate the output.
Grrrrrrr!
Postby BZG Wagon » Fri Dec 28, 2012 11:05 pm
Dell'Orto wrote:Right, that makes sense. Obvious question - but you have checked to see it is actually connected to the relay?
Fairly sure; I connected the wire right after the interior boot switch (i.e. 0v side - diagram below minus the resistor).
Grrrrrrr! wrote:0.3 to 0.6 volts sounds like it is a transistor being turned on to sink a current. Try putting a largish (say 1K ohm) resistor between 12V and the alarm output and seeing if it then becomes 12V, pulling down to ~1V when you activate the output.
Thanks - will give it a try. Would wiring it per the below diagram work (apologies for my MS Paint skills):
BZG Wagon
Postby Bling » Fri Dec 28, 2012 11:56 pm
Ask: XS1V
Postby sergei » Sat Dec 29, 2012 9:56 am
With low active/sink switches you supply "ground" to the relay (while 12V is constant). So your diagram will not work. You will need to drive a separate relay to achieve what you want (providing your alarm is OK and you have not blown the output transistor by applying 12V to it), or if alarm allows it, switch the mode of operation of the output.
Postby BZG Wagon » Mon Dec 31, 2012 9:22 am
Cool thanks for the info. I'll give it a shot & see what happens.
Haven't applied +12v to the boot out so the alarm should be okay.
BZG Wagon
Postby XS1V » Fri Jan 04, 2013 9:37 am
It's a negative out put rated at 200mA. If you need a positive output you will need a relay. Are you running the onboard turbo timer? If so boot out no longer works as this wire becomes secondary ignition control.
Brad
ST205 Group A Rallye #2363
XS1V
Postby BZG Wagon » Fri Jan 04, 2013 12:37 pm
I can't find anywhere in the owners manual on how to program it to Turbo Timer vs. Boot Out. It's not connected to a turbo timer so I'm hoping by default it's set to boot.
BZG Wagon
Postby simonlenihan » Fri Jan 04, 2013 1:56 pm
BZG Wagon wrote:I can't find anywhere in the owners manual on how to program it to Turbo Timer vs. Boot Out. It's not connected to a turbo timer so I'm hoping by default it's set to boot.
From memory it is set to boot out from the factory, hold the button down for 3 seconds and it will produce a negative output.
You can program it to instant boot release too if you want.
Programming instructions are in the installation manual, any AVS installer should help you out.
2011 Toyota Hiace ZL
1994 BMW 740iL e38
simonlenihan
Postby XS1V » Mon Jan 07, 2013 6:17 pm
If you need any programming help then PM me since I design the programming settings and write the manuals 8)
Brad
XS1V
