Remsa ceramic pads?
Remsa ceramic pads?
Postby cat007 » Mon Mar 18, 2013 11:48 am
Has anyone used the 'Ultra' ceramic pads by remsa?
http://www.remsaofamerica.com/remsa_productlines.htm
Thinking about using them on my nana daily Falcon...
Postby Heylin » Tue Mar 19, 2013 2:28 pm
Havent used the Remsa, but if they are a proper ceramic race type pad you dont want it on a daily, you would never get the temps up high enough to obtain the best braking.
I use a BNT brand called "C-Plus" which is a ceramic mix\formula
http://www.adenstyreshop.co.nz/product_ ... ts_id=3211
Currently on Legacy GT-B sedan slightly hotted up (181 kw), slows it down well, minimal brake dust and work well from cold.
I was going to get Resma's but couldnt find any that fitted, C-Plus was better price anyway.
Heylin
Heylin
Postby Dell'Orto » Tue Mar 19, 2013 5:37 pm
They're not a race pad, they're an equivalent to the C- Plus/Repco TQ pad. Low dust and reasonable wearing
Postby cat007 » Tue Mar 19, 2013 5:45 pm
Dell'Orto wrote:They're not a race pad, they're an equivalent to the C- Plus/Repco TQ pad. Low dust and reasonable wearing
Picked some up today - as well as some new rotors as the current ones are pretty worn.
Can't bed in new pads on new rotors though can you? The rotors need to go through some heat cycles first?
Postby Grrrrrrr! » Tue Mar 19, 2013 5:49 pm
cat007 wrote:Can't bed in new pads on new rotors though can you? The rotors need to go through some heat cycles first?
What happens when you buy a new car?
Grrrrrrr!
Postby cat007 » Tue Mar 19, 2013 5:50 pm
I don't know? Never bought one.
Postby Dell'Orto » Tue Mar 19, 2013 5:53 pm
Can't bed in new rotors with old pads, make of that what you will ;)
Postby Grrrrrrr! » Tue Mar 19, 2013 5:54 pm
Do you think it rolls off the end of the production line with used rotors and pads or new ones?
Grrrrrrr!
Postby Kiwi-Corolla » Tue Mar 19, 2013 6:45 pm
Kiwi-Corolla
Postby Bling » Tue Mar 19, 2013 8:24 pm
I just read what the pad packaging says and go with that. Last 4 cars I did this with seem to stop fine. All were new pads + rotors.
What does the pad box say?
Postby Heylin » Tue Mar 19, 2013 10:07 pm
Ive owned lots of cars and done new rotors and pads on all bar 1. Never had an issue. Regular daily driving will bed them in a week or so of heat cycling, just dont track day it and cook them.
Heylin
Heylin
