Mishimoto Gold Heat Tape, Exhaust Wrap, Silicon Air Ducting
Postby Fortyone.co.nz » Fri Apr 12, 2013 12:19 pm
Silicon Air Ducting
A pretty common request is the silicon ducting you see used on many race cars the world over. I know a few people go down to the local plumbing or hardware store and grab some off-the-shelf for simple air-ducting (re: intake) but this is not a good solution for ducting air to the brakes / around the engine / to a turbo because of the heat - the standard plumbing ducting melts! Therefore, silicon is it!
They come in 12ft long rolls in 1in, 2in, 3in or 4in diameters. The semi-rigid ribbed hose keeps its shape when twisted and routed through the chassis or engine bay.
Pricing:
1" $95 delivered
2" $115 delivered
3" $135 delivered
4" $155 delivered
Gold Heat Barrier Tape
Also available is the gold heat tape which you can form and shape most parts of the engine bay - such as the side of the engine block where the air intake passes, or between the oil pan and the headers to reduce heat-soak and so on. You can wrap sensitive electronics, coat the firewall, Turbo inlet and so on, to protect against heat soak or material degradation.
2in wide tape comes in 15ft ($69) or 35ft ($115)
Exhaust Wrap
Lastly, exhaust wrap. Probably needs no introduction - it just does its job.
$115 delivered
Heat Wrap - http://www.mishimoto.com/titanium-heat- ... e-set.html
Gold Heat Barrier Tape - http://www.mishimoto.com/mishimoto-heat-protection.html
Silicon Air Ducting - http://www.mishimoto.com/mishimoto-heat-protection.html
Mac
mac@fortyone.co.nz
http://www.fortyone.co.nz
Facebook: Here
Fortyone.co.nz - For Bride, EBC, KTS, JUN, Tomei, HKS, Trust, Blitz and more!
Fortyone.co.nz
Postby vr4boy » Fri Apr 12, 2013 6:10 pm
Just to confirm the price on the silicone ducting is for a 12 ft (3.6meter) length? Just asking as the pic with the car says 12inchs.
1995 ae101 levin st 20v
vr4boy
Postby Fortyone.co.nz » Fri Apr 12, 2013 6:19 pm
vr4boy wrote:Just to confirm the price on the silicone ducting is for a 12 ft (3.6meter) length? Just asking as the pic with the car says 12inchs.
Yep the price depends on the width you want:
Pricing:
1" $95 delivered
2" $115 delivered
3" $135 delivered
4" $155 delivered
All 12' long
Fortyone.co.nz
Postby vr4boy » Sat Apr 13, 2013 6:30 pm
Sweet will just work out what size I want. How long is the wait on it?
vr4boy
Postby Fortyone.co.nz » Mon Apr 15, 2013 11:36 am
vr4boy wrote:Sweet will just work out what size I want. How long is the wait on it?
Depends on the diameter wanted. Today:
1" in stock in US
2" in stock in US
3" in stock in US
4" ETA 15th April
Fortyone.co.nz
Return to Toyspeed Sponsors
