Ae101 electrical problems
Postby AE82 FXGT » Sun Apr 21, 2013 4:56 pm
Did a search, but couldn't find anything specific to this problem, although I do know that the caps in the ECU give problems.
I have a 1992 Levin 20v here, the check engine light came on and the car lost power. It would still go and start but had very little power.
Anyway, I tried to check the codes by bridging TE1 and E1, but the eng light would flash erratically or would stay be on but dim like it was trying to flash very fast, no two times would it blink the same, I've read plenty of codes from engine check lights but this was just random.
So I put the car in the garage to check it over, and now it won't even start, just cranks over.
I've pulled the ECU out and opened the lid, but the caps seem to be OK. I'll upload a pic.
AE82 FXGT
Postby AE82 FXGT » Sun Apr 21, 2013 5:15 pm
Some pics of ECU
http://imgur.com/a/hfjaN
AE82 FXGT
Postby AE82 FXGT » Sun Apr 21, 2013 5:42 pm
Update: I put the ECU back in, now the car runs, still have Check light, still low on power, but still cant get any codes, now the light does nothing, just stays on?
Has an average idle, not sure if this has to do with me disconnecting the battery while removing the ECU.
So the car starts fine but has a constant check light that I can't check?
I pretty sure it's TE1 and E1 to check, I can't find any info saying otherwise.
As per this thread http://forums.toyspeed.org.nz/viewtopic.php?t=73031&highlight=check+cheque+light+stays my problem could still be caps in the ECU even though it's not visible.
Will look into getting another ECU, but I am open to other ideas!
AE82 FXGT
Postby KinLoud » Sun Apr 21, 2013 8:45 pm
almost certainly ecu = replace
Postby Crucible » Mon Apr 22, 2013 10:50 pm
There are checks you can do..if you had the test equipment.
I agree, replace ecu or try another.
Crucible
Real Life Mechanic
Postby Rob » Thu Apr 25, 2013 8:33 am
Check all your earths aswell
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby AE82 FXGT » Sat Apr 27, 2013 1:37 pm
Just incase anyone searches this thread in the future, all these problems were ECU problems. Got the caps replaced, car runs sweet now.
AE82 FXGT
Postby thaphatty » Sat Apr 27, 2013 6:27 pm
Thanks for updating this, was dealing with similar problem and this thread inspired me to replace the caps anyway. My problem = sorted
double win
thaphatty
Postby AE82 FXGT » Sun Apr 28, 2013 12:34 am
thaphatty wrote:Thanks for updating this, was dealing with similar problem and this thread inspired me to replace the caps anyway. My problem = sorted
double win
No problem,
I hate when I'm sifting through old threads and finally find a thread with the problem I'm experiencing only to find that the OP didn't conclude the thread.
AE82 FXGT
