Postby thegreatestben » Sun May 12, 2013 12:26 am
ch4ng wrote:
Dell'Orto wrote:What is it? I want to say some sort of rotary converted thing with that exhaust tip :lol:
Decided to start it's own little story page like I should've done for the AE111
viewtopic.php?t=90637
MX5?
thegreatestben
Postby Grrrrrrr! » Sun May 12, 2013 3:34 pm
Today... I spent money. Its my birthday so the car gets parts. Strange how that works..
One tilton oil pump, pre-cooler filter, some fittings, compression tester and weld in bungs are now on their way from the land of the free to me. Should sort my oil cooling out once I place the cooler and fit it all up. Just need to redesign the oil pan and get it made/modded before it all arrives.
Grrrrrrr!
Postby Malcolm » Sun May 12, 2013 7:50 pm
I engined!
Postby Stott69 » Sun May 19, 2013 4:59 pm
Finaly finished wiring under the driver side dash. Now boost controler trigger is confirmed to work, and the IC sprayer "works". Now to finish wirring the afr in then just wait on turbo stuff
Stott69
Postby Bling » Sun May 19, 2013 5:33 pm
I had four oil filters and two brake hoses turn up on Friday thanks to Mark. Sadly, rain has meant I can't fit them :x
Postby Leon » Sun May 19, 2013 6:31 pm
Pulled Corolla off lawn.
Idle on the piss.
Appears ISC has packed a sad. So I guess I figure out how to clean one of those, or find a replacement (5AFE AE110)
Postby blindnz » Sun May 19, 2013 6:32 pm
Removed the lower control arm from the Mitsi. Looks like it was bent ex-japan has a yellow mark where the wrinkle is, which I assume is from an inspection.
For 5 bolts there was a lot of swearing!
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Postby Kiwi-Corolla » Sun May 19, 2013 6:46 pm
Leon wrote:Pulled Corolla off lawn.
Idle on the piss.
On the 5A-FE just remove the throttle body and unscrew the four screws underneath to clean out the ISCV (put a lot of pressure on the screws when undoing them though because they're easy to strip). Some people just squirt degreaser from inside the throttle body without removing it but I always preferred to clean it properly.
Kiwi-Corolla
Postby steroidcontaskie » Sun May 19, 2013 7:05 pm
Took apart an A340e gearbox, looked pretty good inside, could still read all the writing on the frictions. Now to clean and see if my extra strong rebuild kit fits :D
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby mytmk3 » Mon May 20, 2013 12:46 am
drove around in circles (ok it was thursday but close enough)
YOUS SIG WAS STUPIDLY LARGE - read the rules - Admin
mytmk3
Postby Mr Ree » Mon May 20, 2013 11:30 am
Good stuff, mate :)
Love seeing whales on track
wak thud gush!
Mr Ree
Postby Pelo » Mon May 20, 2013 12:27 pm
I helped do some work on this "interesting" Altezza. I should really get my own car...
Pelo
Postby skathed » Tue May 21, 2013 11:50 pm
Discovered the crown likes to flash fault codes when its bored
ughhhhhh....
skathed
Postby Grrrrrrr! » Wed May 22, 2013 7:42 pm
Started assembling the fuel system for the rebuilt motor and discovered..
$400 of AN fittings is not a lot of fittings...
That I forgot to order one rather important one.. and ordered another one wrong (female on run instead of female on side branch)
And drilled one out for more flow.. silly 3mm hole in a -6 to m10 adapter wasn't going to cut it. 6mm should do it.\
Add an oil cooler and some mountings and the oil cooling will be sorted too.
Grrrrrrr!
Postby skathed » Sat May 25, 2013 5:00 pm
after a year of putting it of l finally bought a battery for Crown. :D
ughhhhhh....
skathed
Postby ®usty » Sun May 26, 2013 8:40 pm
Finally got around to replacing the park lights with my Spree LED kit ones.
Thinking of getting brighter headlight bulbs aswell, the H1's are just too weak in the low beam projectors.
®usty
Postby Stott69 » Mon May 27, 2013 6:03 pm
The new and the old
Stott69
Postby Stott69 » Mon May 27, 2013 11:51 pm
And progress
Stott69
Postby Dell'Orto » Mon May 27, 2013 11:52 pm
w00t!
Postby CAMB01 » Tue May 28, 2013 1:15 am
Stripped and cleaned new gearbox to check it out and start prepping it for rebuild.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
