anyway i took a pic of where the most oil is coming from and i have taken the belt tension out in the pic. its gotta be the oil pump? or crank shaft seal?
im aware motor has to be pulled out to do oil pump so trying to avoid that.
If you want to run a catch can, at the very least I would recommend getting some vacuum back into the system, by plumbing it back into the turbo inlet.
92mr2paddy wrote:If you want to run a catch can, at the very least I would recommend getting some vacuum back into the system, by plumbing it back into the turbo inlet.
any reason for this? the crank case can get air via the little filter so pressure should def not be able to build up?
