YeMs wrote:Hold the throttle open, up around 6000rpm, with the air filter housing off, then hold your hand flat over the mouth of the carb and press it down to block the air from going, in as you do this hold the throttle wide open. You will feel it suck your hand onto the carb and the engine will choke. Let it off just before it dies and giv the throttle a jab to keep it running then giv it a couple of blips on the throttle.
This causes a huge vacuum inside the carb and draws any debris through any of the jets and sucks it through the motor. Can do it a couple of times to be sure you've given it your best attempt. I can't guarantee it will work, however I've had a bit of success with it and saves pulling the whole carb to bits.
