Caldina ignition help!
Postby speedracer07 » Wed Jul 17, 2013 4:48 pm
hi all,
I'm in the process of installing a Link G4 Storm to run my Caldina 3s-gte (in my 91 Mr2). Got a couple questions that I've been searching for answers for and hope that some of you may be able to shed light?
1) anybody know what is the stock ignition timing for the Caldina? (10 degree's btdc?
2) is the spark edge rising or falling? (thinking it's falling?)
on the offside chance does anybody got a Link basemap for a caldina they would mind sharing with me :D
thanks.
Roshan
SW20 with ST215 motor (fivebob is my hero)
speedracer07
Re: Caldina ignition help!
Postby fivebob » Wed Jul 17, 2013 6:12 pm
speedracer07 wrote:2) is the spark edge rising or falling? (thinking it's falling?)
Rising but it's a 0-5v square wave signal. So be careful that the period that it's held high is as short as possible if the ECU does not output 5v, or you may burn the coils out.
Postby gt4dude » Wed Jul 17, 2013 6:33 pm
10 degrees mechanical advance on idle at operating temp
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby speedracer07 » Thu Jul 18, 2013 7:41 am
thanks guys!
just to confirm my understanding is a rising spark fires on the positive side (as I understand it the signal is going from negative to positive)
the reason I'm double checking my understanding is I've been told that toyota's ignitors are mainly falling spark (going from positive to negative) but I guess the Caldina ignitor's are different?
also any idea of the ignitor model number? Also the injector part number (not the toyota one's as I'm trying to find the manufacturer's spec's).
thanks!
Roshan
speedracer07
Postby fivebob » Thu Jul 18, 2013 2:22 pm
I believe that is correct. However I just checked and now I'm not so sure.
From the following trace it shows IGF, which is the diagnostic return signal firing (pulled low) after the IGN signal goes high, which tends to imply that the coil fires on the rising edge, But the coil primary current is still building and stops on the falling edge :?
Perhaps someone with a better knowledge of auto electrics might be able to determine which is correct.
red=IGN trigger
Blue= IGF diagnostics
Brown= Primary coil current.
Postby speedracer07 » Thu Jul 18, 2013 4:14 pm
Trial and error and tech support talking me through using a 15$ led testlight has lead us to knowing it's falling edge since it releases the pulse on a negative signal.
he explained it to me and I thought I had it straight in my mind but as I typed up what I thought he said I just confused myself more!!
In a nutshell though (and paraphrasing) with the test light hooked up to a ground and touching pin2, if it flashes (ie complete the circuit) then it's falling edge (which the stock caldina coils and ecu do). If the test light is hooked up to power and the ignition trigger flashes then it's rising edge.
hopefully someone else can put that into english? :D
btw it now starts with the aftermarket ecu!! gotta run a vacume line to the map sensor and we should be in business.
thanks again guys!
speedracer07
