SXV10 Camry Keyless entry questions
Postby Stott69 » Sun Jul 28, 2013 2:02 pm
I was about to offer the same. Chips ages away so not to much worry about heat frying that.
Stott69
Postby Mr Ree » Sun Jul 28, 2013 7:17 pm
Thanks, Scott :) Being local is even better for me (read; cheaper lol)
Ill see how I get on tomorrow, and if it runs without it, I will get in touch. :)
wak thud gush!
Mr Ree
Postby Mr Ree » Mon Jul 29, 2013 3:10 pm
I removed the integration relay, and it renders the car useless, which means Im unable to send away the units to be soldered.
Does anybody know of any small owner operated electronics specialists in Welly that I could take both units to, to have the soldered on the spot, without having to leave it there for days?
Thanks again :)
wak thud gush!
Mr Ree
Postby Alex B » Mon Jul 29, 2013 3:20 pm
If it's anything like my old SW20 it used to intercept off the door loom, you just need to unplug it there and plug the door directly into the car, taking the wiring for this box out of the loop.
It's a little hard to explain, but if you look up where the door loom enters the car in above the accelerator pedal it should be pretty obvious.
Postby Mr Ree » Mon Jul 29, 2013 3:50 pm
If I can find a local solderer, Ill just borrow my flatmates car and take both relays with me, but if thats not an option, your info might come in handy, so thank you for that :)
wak thud gush!
Mr Ree
