94' Celsior/LS400.
As mentioned above, most likely the relay or will it be the actual motor itself do you think?
Googled the hell out of this - sorry for the brief post but the title says it all really.
ah so that's the resistor in the motor itself right?Grrrrrrr! wrote:The resistor is burnt out/ or otherwise failed. Only time the motor gets full voltage is on full speed.
