Postby disturbedphil » Thu Aug 08, 2013 9:02 pm
Limp mode... Doesnt sound good
disturbedphil
Postby wde_bdy » Thu Aug 08, 2013 9:04 pm
Stott69 wrote:Is that the light at the end of the tunnel or just someone with a lantern?
I'm going to guess that is a train coming through the tunnel. :lol:
Callum
wde_bdy
Postby captain crescent » Thu Aug 08, 2013 9:22 pm
Na its just some bastard with a tourch bringing you more work
Budweiser is a gay beer. if it isn't a gay beer Sam why are you trying to put it up my arse.
captain crescent
Postby Mr Ree » Thu Aug 08, 2013 10:32 pm
Why limp mode, Scott?
Any fault codes?
Were you in positive pressure at WOT when this happened?
wak thud gush!
Mr Ree
Postby Stott69 » Thu Aug 08, 2013 10:41 pm
May not be limp mode. Started a tech thread with a good description of whats going wrong. Its not throwing codes back at me or telling me its ok. Car seems to drive fine boost and all, just not idle
Stott69
Postby touge rolla » Fri Aug 09, 2013 2:01 am
Put the CT20b on and took it for a drive.
Then did up the bolts holding the bov on :oops:
touge rolla
Postby Soiled » Fri Aug 09, 2013 10:31 am
Yesterday
And a much higher result than expected!!
Soiled
Postby touge_ae101 » Mon Aug 12, 2013 1:38 pm
bought new van over the weekend.. 3L turbo diesel manual supercustom. been lowered, cert, evo 8 wheels and tints. all it needs is some 6x9s, sub + amp and a bigger exhaust. should be good for towing racecars/lugging mountain bikes and engine parts around. also feels good to be back to driving a toyota everyday!
now need to sell the volvo.. anybody want a 2000 V70 wagon 2.3L turbo 5cyl?? will try put up a fir sale thread
touge_ae101
Postby Stott69 » Mon Aug 12, 2013 9:40 pm
With current standings, this looks nice
http://www.trademe.co.nz/motors/used-ca ... 133106.htm
Stott69
Postby Dell'Orto » Mon Aug 12, 2013 9:42 pm
Wrong thread, but that is nice
Postby Stott69 » Mon Aug 12, 2013 10:09 pm
Well Auto sparky booked to come around tomorrow arvo. Im kind of close to throwing in the towel if we cant figure out whats wrong
Stott69
Postby 2jayzgte » Tue Aug 13, 2013 8:56 am
Stott69 wrote:Well Auto sparky booked to come around tomorrow arvo. Im kind of close to throwing in the towel if we cant figure out whats wrong
Whose the Sparkie Scotty????
If you need help go see Al @ Macbilt Engineering he'll sought through your issue's and will bring in his own Sparkie.
2jayzgte
Postby ~SlideWays~ » Tue Aug 13, 2013 10:17 am
Stott69 wrote:With current standings, this looks nice
Having a Mines ecu makes me think it is/was a TS members car, pretty sure there was a build thread. I may be wrong though.
~SlideWays~
Postby Stott69 » Tue Aug 13, 2013 11:16 am
Edyn's sugested this guy, Clint. Ment to be driving to Auckland this weekend so hope to sort it tonight.
Stott69
Postby DeeCee » Tue Aug 13, 2013 5:58 pm
It was listed on JZ forums a while back and it was in repair mode. Guess he fixed everything up
GT Four Adovansu
DeeCee
Postby Stott69 » Tue Aug 13, 2013 7:22 pm
Yea, saw someone say that on the last listing. Mine may just be stuffed caps in the ecu, fingers crossed
Stott69
Postby RobertC » Tue Aug 13, 2013 8:03 pm
sorted a thule 591 for bike carrying duties
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby Bling » Sat Aug 17, 2013 12:00 pm
Put a freshly charged battery in it. Shut the door and the rear windscreen half popped out of the frame. Bit of a WTF moment! I guess I won't be taking it for a WOF check today after all! Got it home for the first time in probably 3-4 months, so that is a plus though. Will have all three cars on one property this arvo.
Postby softlad » Sat Aug 17, 2013 6:04 pm
Fitted a new throttle idle speed valve this morning, what a bitch that is to get to!
The thing that makes it even more painful is the fact it didn't correct the issue with hunting from 1500 - 2000 rpm when idling :cry:
Next job will be to replace every vaccunm pipe, unless any good suggestions?
softlad
Postby Mr Ree » Sat Aug 17, 2013 7:58 pm
Put it on a dyno and guessed 1kw off what it ran...279kw result, and more importantly a baseline figure to compare what my new big plenum FFIM and 82mm throttle body do for the curves.
wak thud gush!
Mr Ree
