2JZ GE Ignition Problem
Postby DLF » Fri Sep 13, 2013 6:05 pm
Does anybody know where the connector for the crankshaft position sensor "B" is on the GE? This is the one that is not inside the distributor.
I've had a look and found a connector underneath the distributor to the left of the water pump which according to the Toyota manual should be the one, but one of my oxy sensors is plugged in to it.
Any ideas?
DLF
