holden_fan2005 wrote:Checked the timing with a timing light?
QikStarlie wrote:sounds like you need to find true tdc. get you a spark plug. weld a bolt to the end of it, just long enough to get the piston to come to rest against it, when rotating the engine towards tdc. jam it in number 1 with engine away from tdc. rotate engine by hand until comes to rest. mark where the crank pulley mark lines up. spin engine back the other way. mark again. true tdc is half way between both marks.
better if you do it with a degree wheel. but should be able to get it pretty good without.
Grrrrrrr! wrote:If piston is at TDC and the markings aren't lined up something is wrong with the pulley/cover/crank combo. Cam timing has nothing to do with when piston is at TDC, nor does ignition timing. No point going any further till you figure out where TDC actually is, otherwise everything is going to be out by however much your index marks are out by.
Grrrrrrr! wrote:When you checked your cam timing did you check it against true TDC or the 5 degrees offset TDC marks on the pulley/cover?
Lloyd wrote:Crank pulley and/or timing covers aren't the original off that motor? Key or slot isn't worn in the crank/pulley that locates the pulley?
Short of those couple of things the marks have to line up when you're on TDC unless there is a big mechanical issue internally. If you're really concerned then pop the cambelt covers off so you can see the actual timing marks down at the crank pulley and see where those line up.
And 5 degrees ignition timing can make a huge different.
strx7 wrote:has your engine got a cam angle sensor or distributor? if either of those, check to make sure the bolt hasn't come loose and it has retarded itself
cat007 wrote: ....to see if mine has spun the rubber a little.
allencr wrote:cat007 wrote: ....to see if mine has spun the rubber a little.
Didn't the screwdriver prove that?
Only use a timing light to check that the ECU's ignition advance is working, that's all.
Time it by its performance, fast & smooth idle and only pings/detonate/pinks/spark knocks a little when abused with the octane of your choice.
