atmosports wrote:I've heard of plenty of tyres failing or falling to bits after using tyre softeners, mainly when used on reasonably new tyres, but as above only heard the stories as haven't really used it
As for cleaning marbles & buildup off tyres, best thing I've found is a heat gun & scrapper(Or a paint stripping gun which is both combined). Though you'll want to do it outdoors as the hot rubber smells & you'll have a big pile of rubber shavings & crap to sweep up after.
Mr Ree wrote:The difference is you always bought your slicks brand new, so the only heat cycles they have seen are the ones you have given them, so they have alot of life left in them.
The ones I have were from an NZV8 team, so have done alot more heat cycles, and I feel they could do with some extra grip now they are 3 years old.
I always keep them in their boxes, in the dark, under the house, but at the end of each session at Taupo in January, I could notice them starting to offer less grip, yest my pressures were bang on target etc.
Im still in the researching stage at the moment though, and havent decided to take the plunge yet, Im just desperate to not have to spend $2k on new rubber, especially if I can avoid it with a small tin of liquid.
Users browsing this forum: Google [Bot] and 48 guests
