Solid pinion spacer for diff?
Postby cat007 » Thu Jan 23, 2014 11:10 am
Hey all
Just wondering if anyone local can supply a solid pinion spacer kit for my MK3 supra diff?
Found an american company that does them, but by the time it's shipped here the cost is ~$100!
Hunt
Re: Solid pinion spacer for diff?
Postby AE25 » Tue Feb 04, 2014 12:39 am
a new toyota crush tube is around $45 ...
are ya handy with a lathe and tin snips?
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby cat007 » Sat Feb 15, 2014 7:58 am
AE25 wrote:a new toyota crush tube is around $45 ...
Heard bad things with using the Toyota crush tube.
Ended up buying from Weird Performance and solid pinion spacer kit. Pretty pricey but at least it'll mean it'll be set up right!
Postby AE25 » Mon Feb 17, 2014 8:06 pm
lol weir performance
its only with decent torque that they squash further which reduces pinion bearing preload, causing a whine.
I use the std crush tube with a 7.5" 2way lsd for drifting a 150kw ish 1000kg corolla. hasn't made any noises after a dozen track days. but a mates 1jz 13psi cressida got whiney not long after a full rebuild 7.5" diff and i'm assuming the crush tube is the cause.
E2 & E7 fanatic
AE25
Postby cat007 » Mon Feb 17, 2014 8:55 pm
AE25 wrote:lol weir performance
Why lol @ Weir performance?
Yeah I've had a bad wine from an F series supra diff (from my original n/a 1G auto supra) and I think that's what happened as well.
Postby Bling » Sun Feb 23, 2014 4:07 pm
I think it was because you said weird performance.
Users browsing this forum: Google [Bot] and 32 guests
